I use a Docker Container on a Synology NAS DS 218+
I want to secure Node-Red like following https://nodered.org/docs/user-guide/runtime/securing-node-red#editor--admin-api-security
But how can i do it on the Synology-NAS-Docker-APP?
Kind regards
E_T
Kind regards
E_T
If you've mounted the container's /data path to a folder on your NAS (use the Volume tab), you can just access the settings.js file for the container and modify it accordingly. Restart the container after editing settings.js to apply the changes.
Thank you, NoweWorks, I will try it!
E_T
The Volume-Tab shows only the status of mounted volumes, for me there is no way to mount a volume!
The second problem is, i must install node-red-admin in the container like
npm install -g --unsafe-perm node-red-admin
But the terminal-window in docker do not accept the command.
Ok, I have bypassed the problem!
I take this command:
node -e "console.log(require('bcryptjs').hashSync(process.argv[1], 8));" your-password-here
So now i must mount the volume!
Please read the documentation on permissions.
Thank you!
I will have a look to the user IDs!
E_T
On Synology NAS the command usermod are not available!
I will look.
E_T
i made a new user "node-red" and a Group "node-red"
with sudo vi /etc/passwd i changed the user Id from "node-red" to 1000
with sudo vi /etc/group i changed the group Id from "node-red" to 1000
after restart the NAS no user node-red were listet.
Login with user node-red was possible, but no Docker was available.
E_T
