I am trying to send data from Node-RED to Elasticsearch, but I receive the following error after deploy the time stamp:
Elasticsearch ERROR: 2018-07-17T14:30:15Z
Error: Request error, retrying
HEAD http://localhost/twitterr/tweets/1 => connect ECONNREFUSED 127.0.0.1:80
at Log.error (/home/workdb/.node-red/node_modules/elasticsearch/src/lib/log.js:225:56)
at checkRespForFailure (/home/workdb/.node-red/node_modules/elasticsearch/src/lib/transport.js:258:18)
at HttpConnector. (/home/workdb/.node-red/node_modules/elasticsearch/src/lib/connectors/http.js:157:7)
at ClientRequest.bound (/home/workdb/.node-red/node_modules/elasticsearch/node_modules/lodash/dist/lodash.js:729:21)
at emitOne (events.js:116:13)
at ClientRequest.emit (events.js:211:7)
at Socket.socketErrorListener (_http_client.js:387:9)
at Socket.emit (events.js:211:7)
at emitErrorNT (internal/streams/destroy.js:64:8)
at _combinedTickCallback (internal/process/next_tick.js:138:11)
at process._tickCallback (internal/process/next_tick.js:180:9)
Elasticsearch WARNING: 2018-07-17T14:30:15Z
Unable to revive connection: http://localhost/
No living connections
17 Jul 11:30:15 - [error] [es-exists:cee9ae59.c86a2] Error: No Living connection
I am using this library:
node-red-contrib-elasticsearch-continued
0.1.0
Anyone knows how to fix this?
Well my guess - based on the log - is you don’t have a connection to the server and you need to fix that
Thank you for the reply!
When I tested in Node.js everything is ok, but in Node-RED it doens't work
Ok, maybe I just fix this haha, but there is a new error:
17 Jul 14:00:47 - [error] [get:4c6969c1.2bdd08] ReferenceError: documentType is not defined
My goodness
And where is that error coming from?
Not having your flow (and since I don't even know what 'elasticsearch' search is, it probably wouldn't help) it is hard to guess where that message is from.
You might want to add a 'catch' node connected to a debug node (omplete msg object) and see what that gives you in the debug panel
When I use catch node other nodes doesn't work
I believe if you look at the debug panel where the error mesage is showing, in the first line it shows the time and node. If you click on the node number, it will highlight which node the message is coming from.
so which node is it?
Have you tried leaving the ID, index and type blank and passing them to the node in the message?
Or open an issue against the node on github.
The GET node are making troubles haha.
Well, leaving just Output Elasticsearch node I get another error o///
"RangeError: Maximum call stack size exceeded"
I tried, but I get this error:
TypeError: Unable to build a path with those params. Supply at least index, type, id.
About github, this is a good idea.
so what message did you send ?
No offense, but it seems to me you need to first get a better grasp of Elastic. The errors you report are due to incorrect use of this ( excellent) search engine.
No offense, but may you explain how this excellent search engine works? We would appreciate it very much if you show us how to set it up correctly
Hi @anmobor,
this topic is over 2 years old. If you have a new question about ElasticSearch and Node-RED, it would be better to start a new topic.
Hi @knolleary I am trying to do the same and I don't see any answer with a solution. Do you want me to open another topic with the same question?
Do you mean you are hitting the same error as the original question:
Or something else?
As you can see, a number of questions were asked about what the user was trying to do that went unanswered. If you want help, you'll need to explain in more detail what you are trying to do, what you have done so far, and what is not working.
Given this thread is 2 years old, it may make sense for you to ask it as a new thread, otherwise your question may get overlooked.
@knolleary you are right, I will open a new one
@knolleary you are right. There's no need to open a new one because I solved the problem using the component 'elasticsearch-cient node' and setting the field Elastic cloud with the cluster id the user and password, it worked perfectly, I sent the msg.payload in the append field and I could store to elasticsearch perfectly.
Thank you
