Node red Event loop blocking when modbus timedout
Whenever the modbus timedout while reading registers, my node red event loop is blocking for a specific time, how to resolve this ?
Which modbus nodes are you using?
How do you know it is blocking?
Also, if you remove the output wires from the modbus node and replace with just a debug node does it still block?
node-red-contrib-modbus
Using Modbus TCP
It is happening for when i use complex flows, when using single modbus flow its good
Please answer:
