Node-red-html-to-pdf Error
Hi, i'm use html to pdf node, when i send html to node, return this error:
TypeError: Cannot read properties of undefined (reading 'split')
This is my code:
        "id": "3f78bec97e2f1517",
        "type": "html-to-pdf",
        "z": "926d9efbb492c064",
        "format": "A4",
        "zoom": 100,
        "orientation": "Portrait",
        "width": "",
        "height": "",
        "widthUnit": "cm",
        "heightUnit": "cm",
        "marginTop": 1,
        "marginLeft": 1,
        "marginBottom": 1,
        "marginRight": 1,
        "marginTopUnits": "cm",
        "marginLeftUnits": "cm",
        "marginBottomUnits": "cm",
        "marginRightUnits": "cm",
        "omitBackground": false,
        "printGraphics": true,
        "x": 370,
        "y": 260,
                "323ae64d46b2979b"
        "id": "b6d73b18.9b6a48",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "<table>\n  <thead>\n    <tr>\n      <th>Nombre</th>\n      <th>Apellido</th>\n      <th>Edad</th>\n    </tr>\n  </thead>\n  <tbody>\n    <tr>\n      <td>John</td>\n      <td>Doe</td>\n      <td>30</td>\n    </tr>\n    <tr>\n      <td>Jane</td>\n      <td>Doe</td>\n      <td>25</td>\n    </tr>\n  </tbody>\n</table>",
        "output": "str",
        "x": 160,
        "y": 260,
                "1af36e33.48c6c7",
                "3f78bec97e2f1517",
                "bc46de2db8066611"
        "id": "1af36e33.48c6c7",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 410,
        "y": 180,
        "id": "323ae64d46b2979b",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 570,
        "y": 260,
        "id": "01fc7c38c7d214e2",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 160,
        "y": 120,
                "b6d73b18.9b6a48"
        "id": "bc46de2db8066611",
        "type": "function",
        "name": "function 1",
        "func": "msg.html = msg.payload;\nmsg.filename = \"test.pdf\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 200,
        "y": 420,
                "156d280183658352"
        "id": "156d280183658352",
        "format": "A4",
        "zoom": 100,
        "width": "",
        "height": "",
        "widthUnit": "cm",
        "heightUnit": "cm",
        "marginTop": 1,
        "marginLeft": 1,
        "marginBottom": 1,
        "marginRight": 1,
        "x": 450,
        "y": 500,
                "a28316945f0fda9e"
        "id": "a28316945f0fda9e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 670,
        "y": 500,
I have everything running in a docker container with the following version: nodered/node-red:3.0.2
What can be wrong? I can't find much documentation with examples of how to use it correctly, or maybe I'm not looking for it right.
Hi @WilsonOviedo - Welcome to the forums
I'm not sure of any prerequisites in using this node (assuming all required libs are installed)
but your code seems fine - You will need to raise this issue with the author of the node.
Hi, @marcus-j-davies, thaks
There is no mention of any prerequisites to install it. I will make your suggestion, I will ask the author.
Thank you very much for your answer.
