There is 1 day of difference between the database and the ui-form. Sorry
Example is below
[{"id":"9d60d084003b46ca","type":"tab","label":"Flow 5","disabled":false,"info":"","env":[]},{"id":"3483688aa2fe73f8","type":"debug","z":"9d60d084003b46ca","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1230,"y":260,"wires":[]},{"id":"6aadc2e9e55a5cee","type":"ui_table","z":"9d60d084003b46ca","group":"8220361faab44749","name":"resaults","order":1,"width":12,"height":4,"columns":[{"field":"date","title":"Date","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"rga_number","title":"RGA #","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"pump_number","title":"Pump#","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"acc_rej","title":"Acc/Rej","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"contaminated","title":"Contaminated","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":1,"cts":true,"x":1600,"y":300,"wires":[["03ba6377d589819b","7d21713fea51f9ed"]]},{"id":"03ba6377d589819b","type":"function","z":"9d60d084003b46ca","name":"quality_rga to form","func":"var id =msg.payload.id\nvar rganum = msg.payload.rga_number\nvar gw = msg.payload.LC_GW\nvar comp = msg.payload.company\nvar deft = msg.payload.defects\nvar dtp = msg.payload.days_to_process\nvar dr = msg.payload.date_rec\nvar adp = msg.payload.actual_days_process\nvar ar = msg.payload.acc_rej\nvar pump = msg.payload.pump_number\nvar cont = msg.payload.contaminated\nvar bear = msg.payload.bearing\nvar bvend = msg.payload.b_vendor\nvar seal = msg.payload.seal\nvar svend = msg.payload.s_vendor\nvar wo = msg.payload.work_order\nvar dou = msg.payload.douwei_num\nvar sct = msg.payload.sc_trace\nvar db = msg.payload.date_built_vendor\nvar rc = msg.payload.reason_code\nvar mil = msg.payload.milage\nvar vin = msg.payload.vin\nvar dol = msg.payload.issued_refund\nvar ask = msg.payload.asking_refund\nvar comment = msg.payload.additional_comments\n\nlet drec = new Date(msg.payload.date)\nlet dateTimeLocal = new Date(drec.getTime() - (drec.getTimezoneOffset() * 60000)).toISOString().slice(0, 23).replace(\"T\", \" \");\nlet daterec = dateTimeLocal.slice(0, 10)\n\nlet datecom = new Date(msg.payload.date_comp_rga)\nlet dateTimeLocal1 = new Date(datecom.getTime() - (datecom.getTimezoneOffset() * 60000)).toISOString().slice(0, 23).replace(\"T\", \" \");\nlet datecomp = dateTimeLocal1.slice(0, 10)\n\nlet tof = new Date(msg.payload.to_office)\nlet dateTimeLocal2 = new Date(tof.getTime() - (tof.getTimezoneOffset() * 60000)).toISOString().slice(0, 23).replace(\"T\", \" \");\nlet gto = dateTimeLocal2.slice(0, 10)\n\nlet t = new Date(msg.payload.follow_up_meeting)\nlet dateTimeLocal3 = new Date(t.getTime() - (t.getTimezoneOffset() * 60000)).toISOString().slice(0, 23).replace(\"T\", \" \");\nlet tm = dateTimeLocal3.slice(0, 10)\n\nif (ar == \"Accepted\"){ar = true}\nif( ar == \"Rejected\"){ar = false}\nif(cont == \"Yes\"){cont= true}\nif(cont == \"No\"){cont= false}\n\n\nmsg.payload = {\"id\":id,\n \"daterec\": daterec,\n\"rganum\":rganum,\n\"gw\":gw,\n\"comp\":comp,\n\"deft\":deft,\n\"datecomp\":datecomp,\n\"gto\":gto,\n\"dtp\":dtp,\n\"tm\":tm,\n\"dr\":dr,\n\"adp\":adp,\n\"ar\":ar,\n\"pump\":pump,\n\"cont\":cont,\n\"bear\":bear,\n\"bvend\":bvend,\n\"seal\":seal,\n\"svend\":svend,\n\"wo\":wo,\n\"dou\":dou,\n\"sct\":sct,\n\"db\":db,\n\"rc\":rc,\n\"mil\":mil,\n\"vin\":vin,\n\"dol\":dol,\n\"ask\":ask,\n\"comment\":comment}\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1810,"y":300,"wires":[["ce6a32cbfc01a85b","36026c71718f994f"]]},{"id":"9dac474874231066","type":"debug","z":"9d60d084003b46ca","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1550,"y":360,"wires":[]},{"id":"9000c88741efd412","type":"split","z":"9d60d084003b46ca","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":350,"y":200,"wires":[["eec17113c0fcb638","5fa145e8b4b4c68d"]]},{"id":"428cbc64c6ac3f6e","type":"join","z":"9d60d084003b46ca","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1070,"y":320,"wires":[["4a5c9a6be60b59f8","3483688aa2fe73f8"]]},{"id":"b72a583d68850910","type":"trigger","z":"9d60d084003b46ca","name":".","op1":"","op2":"","op1type":"nul","op2type":"str","duration":"250","extend":true,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":810,"y":380,"wires":[["6ca3223f0eaa5822"]]},{"id":"6ca3223f0eaa5822","type":"change","z":"9d60d084003b46ca","name":".","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"complete","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":380,"wires":[["428cbc64c6ac3f6e"]]},{"id":"5fa145e8b4b4c68d","type":"change","z":"9d60d084003b46ca","name":"","rules":[{"t":"change","p":"payload.acc_rej","pt":"msg","from":"1","fromt":"num","to":"Accepted","tot":"str"},{"t":"change","p":"payload.acc_rej","pt":"msg","from":"0","fromt":"num","to":"Rejected","tot":"str"},{"t":"change","p":"payload.contaminated","pt":"msg","from":"1","fromt":"num","to":"Yes","tot":"str"},{"t":"change","p":"payload.contaminated","pt":"msg","from":"0","fromt":"num","to":"No","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":320,"wires":[["428cbc64c6ac3f6e","b72a583d68850910"]]},{"id":"4a5c9a6be60b59f8","type":"switch","z":"9d60d084003b46ca","name":"","property":"payload","propertyType":"msg","rules":[{"t":"nempty"},{"t":"empty"}],"checkall":"true","repair":false,"outputs":2,"x":1210,"y":320,"wires":[["b7a0bd2eabc94be0","6aadc2e9e55a5cee"],["9dac474874231066"]]},{"id":"eec17113c0fcb638","type":"debug","z":"9d60d084003b46ca","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":220,"wires":[]},{"id":"018c14e1477f7426","type":"inject","z":"9d60d084003b46ca","name":"trigger","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"id\":null,\"daterec\":\"2022-10-31\",\"rganum\":\"13293\",\"gw\":\"GW\",\"comp\":\"DIESEL FORWARD\",\"deft\":1,\"datecomp\":\"2022-11-22\",\"gto\":\"2022-11-22\",\"dtp\":16,\"tm\":\"\",\"dr\":\"\",\"adp\":0,\"ar\":true,\"pump\":\"18-2037\",\"cont\":false,\"bear\":\"81-WIR1630139W2\",\"bvend\":\"147\",\"seal\":\"81-106MAC\",\"svend\":\"48\",\"wo\":\"33559\",\"dou\":\"\",\"sct\":\"\",\"db\":\"4/20/2021\",\"rc\":19,\"mil\":\"\",\"vin\":\"\",\"dol\":\"\",\"ask\":null,\"comment\":\"Not Restock, Pump passed print measurement & pressure CTS test w/original o-ring @ -.02SCCM, silicone is built up on the o-ring from the customer\"}","payloadType":"json","x":230,"y":280,"wires":[["9000c88741efd412"]]},{"id":"b7a0bd2eabc94be0","type":"debug","z":"9d60d084003b46ca","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1550,"y":240,"wires":[]},{"id":"ce6a32cbfc01a85b","type":"ui_form","z":"9d60d084003b46ca","name":"","label":"Search Fields","group":"8220361faab44749","order":2,"width":12,"height":1,"options":[{"label":"id","value":"id","type":"number","required":false,"rows":null},{"label":"Date Rec","value":"daterec","type":"date","required":false,"rows":null},{"label":"RGA Number","value":"rganum","type":"text","required":false,"rows":null},{"label":"LC / GW","value":"gw","type":"text","required":false,"rows":null},{"label":"Company","value":"comp","type":"text","required":false,"rows":null},{"label":"Defects","value":"deft","type":"number","required":false,"rows":null},{"label":"Date Completed Rga","value":"datecomp","type":"date","required":false,"rows":null},{"label":"Date to Office","value":"gto","type":"date","required":false,"rows":null},{"label":"Days to Process","value":"dtp","type":"number","required":false,"rows":null},{"label":"Follow Up Meeting","value":"tm","type":"date","required":false,"rows":null},{"label":"Meeting Notes","value":"dr","type":"text","required":false,"rows":null},{"label":"Days To Credit","value":"adp","type":"number","required":false,"rows":null},{"label":"Accept?","value":"ar","type":"checkbox","required":false,"rows":null},{"label":"Pump #","value":"pump","type":"text","required":false,"rows":null},{"label":"Contaminated?","value":"cont","type":"checkbox","required":false,"rows":null},{"label":"Bearing Part #","value":"bear","type":"text","required":false,"rows":null},{"label":"Bearing Vendor","value":"bvend","type":"text","required":false,"rows":null},{"label":"Seal Part #","value":"seal","type":"text","required":false,"rows":null},{"label":"Seal Vendor","value":"svend","type":"text","required":false,"rows":null},{"label":"Work Order #","value":"wo","type":"text","required":false,"rows":null},{"label":"DOUWEI #","value":"dou","type":"text","required":false,"rows":null},{"label":"S.C. Trace","value":"sct","type":"text","required":false,"rows":null},{"label":"Date Built / Vendor Name","value":"db","type":"text","required":false,"rows":null},{"label":"Reason Code","value":"rc","type":"text","required":false,"rows":null},{"label":"Milage","value":"mil","type":"text","required":false,"rows":null},{"label":"VIN #","value":"vin","type":"text","required":false,"rows":null},{"label":"Refund Delivered","value":"dol","type":"text","required":false,"rows":null},{"label":"Asking Refund","value":"ask","type":"number","required":false,"rows":null},{"label":"Comments","value":"comment","type":"multiline","required":false,"rows":3}],"formValue":{"id":"","daterec":"","rganum":"","gw":"","comp":"","deft":"","datecomp":"","gto":"","dtp":"","tm":"","dr":"","adp":"","ar":false,"pump":"","cont":false,"bear":"","bvend":"","seal":"","svend":"","wo":"","dou":"","sct":"","db":"","rc":"","mil":"","vin":"","dol":"","ask":"","comment":""},"payload":"","submit":"submit","cancel":"cancel","topic":"topic","topicType":"msg","splitLayout":true,"className":"","x":2140,"y":300,"wires":[[]]},{"id":"7d21713fea51f9ed","type":"debug","z":"9d60d084003b46ca","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1790,"y":260,"wires":[]},{"id":"36026c71718f994f","type":"debug","z":"9d60d084003b46ca","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1990,"y":260,"wires":[]},{"id":"8220361faab44749","type":"ui_group","name":"Search","tab":"4b9b9fcf6d5a669a","order":7,"disp":true,"width":12,"collapse":false,"className":""},{"id":"4b9b9fcf6d5a669a","type":"ui_tab","name":"Quality","icon":"","disabled":false,"hidden":false}]
I tried to add this function and it made it two days out.
let d = new Date(msg.payload.date) let dateTimeLocal = new Date(d.getTime() - (d.getTimezoneOffset() * 60000)).toISOString().slice(0,23).replace("T"," "); let dateLocal = dateTimeLocal.slice(0,10)
The database is local and is in central time America/chicgo time
