Node-red-log-io - Questions and comments
First, thank you for node-red-log-io (node) - Node-RED it looks really promising.
Being, so far, a rather heavy user of flogger I am giving it a go.
It doesn't seem to be possible to set dynamically the log file name with a msg. Have I missed something ?
I log messages out of mqtt in nodes. I need to split the logging using part of the topic (slightly more subtle than that, but, in short this is what I need). At the moment, it seems that I can't.
If the logIO node is active and then greying the components button, it looks like one must deploy the node for the log to stop, unlike the usual debug.
Then, if I want to re-enable logging, it looks like I need to deploy in full for the change to be effective. Only deploying the changed node (here logIO) is not enough.
2 posts were merged into an existing topic: [Announce] node-red-log-io
