NODE-RED- Low Code android app builder
Hi Team,
I built a dashboard in node red utilizing two softwares and connecting them via their APIs. It works fine, but I reached the point when it would be better to have it in an app. So what I would like to achieve is, to "move" my dashboard into an Android app and would be managed from the app not the dashboard.
I have never built an Android app so I was thinking of some kind of low code solution.
I hope it makes sense and you can advise me where to go.
The new dashboard @flowfuse/node-red-dashboard will install as a PWA (progressive Web app) on Android. If that is not what you want please explain why you want it as an app.
I will check this out. Thanks. The main reasons why i want it as an app to learn and also i want to utilize the biometric security of the phone to open the app.
In that case you will, I think, need to write an app. Which is something you will need to research the various methods that can be used. That isn't anything to do with node-red.
