This is the flow im using,
[{"id":"29c5c29f.0ccade","type":"ui_gauge","z":"5bbec9a5.28ca08","name":"","group":"c998f325.2a7bc","order":2,"width":0,"height":0,"gtype":"gage","title":"CPU Temperature","label":"Degrees F","format":"{{value}}","min":"40","max":"150","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1099,"y":104,"wires":[]},{"id":"756e68c1.63f4f8","type":"exec","z":"5bbec9a5.28ca08","command":"vcgencmd measure_temp","addpay":false,"append":"","useSpawn":"","timer":"","name":"RPi Temp.","x":496,"y":137,"wires":[["cd08e15.bd9662"],[],[]]},{"id":"8c053f83.c1a2c","type":"inject","z":"5bbec9a5.28ca08","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":"","x":290.5,"y":145.25,"wires":[["756e68c1.63f4f8","97a598e9.2e0018","7a86592f.679968"]]},{"id":"cd08e15.bd9662","type":"function","z":"5bbec9a5.28ca08","name":"","func":"str = msg.payload\nmsg.payload = str.substring(5,9);\nreturn msg;","outputs":1,"noerr":0,"x":676,"y":137,"wires":[["a845c6d0.b035e8"]]},{"id":"264838c0.f9ead8","type":"ui_button","z":"5bbec9a5.28ca08","name":"","group":"ca8f3c67.b213c","order":2,"width":0,"height":0,"label":"Reboot","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":266,"y":517,"wires":[["5ce5c280.b83d4c"]]},{"id":"5ce5c280.b83d4c","type":"exec","z":"5bbec9a5.28ca08","command":"sudo reboot","addpay":false,"append":"","useSpawn":"","timer":"","name":"Reboot","x":484,"y":517,"wires":[[],[],[]]},{"id":"f82e6c7a.7c664","type":"ui_button","z":"5bbec9a5.28ca08","name":"","group":"ca8f3c67.b213c","order":3,"width":0,"height":0,"label":"Shutdown","color":"","bgcolor":"red","icon":"","payload":"","payloadType":"str","topic":"","x":274.5,"y":561.25,"wires":[["8b933e22.73a26"]]},{"id":"8b933e22.73a26","type":"exec","z":"5bbec9a5.28ca08","command":"sudo shutdown -h now","addpay":false,"append":"","useSpawn":"","timer":"","name":"Shutdown","x":495.5,"y":579.25,"wires":[[],[],[]]},{"id":"b21ec346.6e944","type":"ui_chart","z":"5bbec9a5.28ca08","name":"","group":"c998f325.2a7bc","order":3,"width":0,"height":0,"label":"","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":true,"x":1089,"y":163,"wires":[[],[]]},{"id":"97a598e9.2e0018","type":"exec","z":"5bbec9a5.28ca08","command":"top -d 0.5 -b -n2 | grep \"Cpu(s)\"|tail -n 1 | awk '{print $2 + $4}'","addpay":false,"append":"","useSpawn":"","timer":"","name":"CPU Load","x":496,"y":217,"wires":[["3ad9f72a.5cd698"],[],[]]},{"id":"7a86592f.679968","type":"exec","z":"5bbec9a5.28ca08","command":"free | grep Mem | awk '{print 100*($4+$6+$7)/$2}'","addpay":false,"append":"","useSpawn":"","timer":"","name":"Free Memory","x":496,"y":297,"wires":[["f6b57c6b.c6224","8f6b01b5.29a2"],[],[]]},{"id":"3ad9f72a.5cd698","type":"ui_gauge","z":"5bbec9a5.28ca08","name":"","group":"c998f325.2a7bc","order":1,"width":0,"height":0,"gtype":"gage","title":"Processor","label":"CPU % Usage","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":856,"y":217,"wires":[]},{"id":"f6b57c6b.c6224","type":"ui_gauge","z":"5bbec9a5.28ca08","name":"","group":"dd04219d.3c55d","order":1,"width":0,"height":0,"gtype":"gage","title":"Memory","label":"RAM","format":"{{value.toFixed(1)}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":856,"y":297,"wires":[]},{"id":"efb4235d.83a2e","type":"exec","z":"5bbec9a5.28ca08","command":"df -h","addpay":false,"append":"","useSpawn":"","timer":"","name":"Disk Usage","x":496,"y":377,"wires":[["441ec2d8.919dac"],[],[]]},{"id":"4ef67924.4a3d48","type":"ui_gauge","z":"5bbec9a5.28ca08","name":"","group":"67638498.5c2e5c","order":1,"width":0,"height":0,"gtype":"gage","title":"Disk","label":"Usage","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"x":856,"y":377,"wires":[]},{"id":"441ec2d8.919dac","type":"function","z":"5bbec9a5.28ca08","name":"","func":"var re = /([0-9]{2})%/\nvar idx = msg.payload.search(re);\nvar str = msg.payload;\nif (idx >=0) {\n str = msg.payload.substring(idx, idx + 2);\n}\nmsg.payload = str;\nreturn msg;","outputs":1,"noerr":0,"x":676,"y":377,"wires":[["4ef67924.4a3d48"]]},{"id":"71c53119.f34e6","type":"inject","z":"5bbec9a5.28ca08","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":false,"onceDelay":"","x":296,"y":377,"wires":[["efb4235d.83a2e"]]},{"id":"a845c6d0.b035e8","type":"function","z":"5bbec9a5.28ca08","name":"convert C to F","func":"var tempc = msg.payload;\n tempf = tempc * 9/5 + 32;\n tempf = Math.round(tempf * 10) / 10;\n msg.payload = tempf;\n return msg;\n","outputs":1,"noerr":0,"x":870,"y":125,"wires":[["29c5c29f.0ccade","b21ec346.6e944"]]},{"id":"8f6b01b5.29a2","type":"debug","z":"5bbec9a5.28ca08","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1100,"y":322,"wires":[]},{"id":"c998f325.2a7bc","type":"ui_group","z":"","name":"Col1","tab":"19ff6ee5.9a1551","order":1,"disp":false,"width":"6"},{"id":"ca8f3c67.b213c","type":"ui_group","z":"","name":"Actions","tab":"19ff6ee5.9a1551","order":4,"disp":true,"width":"6"},{"id":"dd04219d.3c55d","type":"ui_group","z":"","name":"Col2","tab":"19ff6ee5.9a1551","order":2,"disp":false,"width":"6"},{"id":"67638498.5c2e5c","type":"ui_group","z":"","name":"Col3","tab":"19ff6ee5.9a1551","order":3,"disp":false,"width":"6"},{"id":"19ff6ee5.9a1551","type":"ui_tab","z":"","name":"RPi Control","icon":"dashboard","order":1}]
My issue is it wont show the ram data. Im getting a error in debug of
"TypeError: Cannot read property 'toFixed(1)' of undefined
