Here is the settings.js file
- Copyright JS Foundation and other contributors, http://js.foundation
- Licensed under the Apache License, Version 2.0 (the "License");
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an "AS IS" BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
// The https setting requires the fs module. Uncomment the following
// to make it available:
//var fs = require("fs");
module.exports = {
// the tcp port that the Node-RED web server is listening on
uiPort: process.env.PORT || 1880,
// By default, the Node-RED UI accepts connections on all IPv4 interfaces.
// To listen on all IPv6 addresses, set uiHost to "::",
// The following property can be used to listen on a specific interface. For
// example, the following would only allow connections from the local machine.
//uiHost: "127.0.0.1",
// Retry time in milliseconds for MQTT connections
mqttReconnectTime: 15000,
// Retry time in milliseconds for Serial port connections
serialReconnectTime: 15000,
// Retry time in milliseconds for TCP socket connections
//socketReconnectTime: 10000,
// Timeout in milliseconds for TCP server socket connections
// defaults to no timeout
//socketTimeout: 120000,
// Maximum number of messages to wait in queue while attempting to connect to TCP socket
// defaults to 1000
//tcpMsgQueueSize: 2000,
// Timeout in milliseconds for HTTP request connections
// defaults to 120 seconds
//httpRequestTimeout: 120000,
// The maximum length, in characters, of any message sent to the debug sidebar tab
debugMaxLength: 1000,
// The maximum number of messages nodes will buffer internally as part of their
// operation. This applies across a range of nodes that operate on message sequences.
// defaults to no limit. A value of 0 also means no limit is applied.
//nodeMessageBufferMaxLength: 0,
// To disable the option for using local files for storing keys and certificates in the TLS configuration
// node, set this to true
//tlsConfigDisableLocalFiles: true,
// Colourise the console output of the debug node
//debugUseColors: true,
// The file containing the flows. If not set, it defaults to flows_<hostname>.json
//flowFile: 'flows.json',
// To enabled pretty-printing of the flow within the flow file, set the following
// property to true:
//flowFilePretty: true,
// By default, credentials are encrypted in storage using a generated key. To
// specify your own secret, set the following property.
// If you want to disable encryption of credentials, set this property to false.
// Note: once you set this property, do not change it - doing so will prevent
// node-red from being able to decrypt your existing credentials and they will be
// lost.
//credentialSecret: "a-secret-key",
// By default, all user data is stored in a directory called `.node-red` under
// the user's home directory. To use a different location, the following
// property can be used
//userDir: '/home/nol/.node-red/',
// Node-RED scans the `nodes` directory in the userDir to find local node files.
// The following property can be used to specify an additional directory to scan.
//nodesDir: '/home/nol/.node-red/nodes',
// By default, the Node-RED UI is available at http://localhost:1880/
// The following property can be used to specify a different root path.
// If set to false, this is disabled.
//httpAdminRoot: '/admin',
// Some nodes, such as HTTP In, can be used to listen for incoming http requests.
// By default, these are served relative to '/'. The following property
// can be used to specifiy a different root path. If set to false, this is
// disabled.
//httpNodeRoot: '/red-nodes',
// The following property can be used in place of 'httpAdminRoot' and 'httpNodeRoot',
// to apply the same root to both parts.
//httpRoot: '/red',
// When httpAdminRoot is used to move the UI to a different root path, the
// following property can be used to identify a directory of static content
// that should be served at http://localhost:1880/.
//httpStatic: '/home/nol/node-red-static/',
// The maximum size of HTTP request that will be accepted by the runtime api.
// Default: 5mb
//apiMaxLength: '5mb',
// If you installed the optional node-red-dashboard you can set it's path
// relative to httpRoot
//ui: { path: "ui" },
// Securing Node-RED
// To password protect the Node-RED editor and admin API, the following
// property can be used. See http://nodered.org/docs/security.html for details.
//adminAuth: {
// type: "credentials",
// users: [{
// username: "admin",
// password: "$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN.",
// permissions: "*"
// To password protect the node-defined HTTP endpoints (httpNodeRoot), or
// the static content (httpStatic), the following properties can be used.
// The pass field is a bcrypt hash of the password.
// See http://nodered.org/docs/security.html#generating-the-password-hash
//httpNodeAuth: {user:"user",pass:"$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN."},
//httpStaticAuth: {user:"user",pass:"$2a$08$zZWtXTja0fB1pzD4sHCMyOCMYz2Z6dNbM6tl8sJogENOMcxWV9DN."},
// The following property can be used to enable HTTPS
// See http://nodejs.org/api/https.html#https_https_createserver_options_requestlistener
// for details on its contents.
// See the comment at the top of this file on how to load the `fs` module used by
// this setting.
//https: {
// key: fs.readFileSync('privatekey.pem'),
// cert: fs.readFileSync('certificate.pem')
// The following property can be used to cause insecure HTTP connections to
// be redirected to HTTPS.
//requireHttps: true,
// The following property can be used to disable the editor. The admin API
// is not affected by this option. To disable both the editor and the admin
// API, use either the httpRoot or httpAdminRoot properties
//disableEditor: false,
// The following property can be used to configure cross-origin resource sharing
// in the HTTP nodes.
// See https://github.com/troygoode/node-cors#configuration-options for
// details on its contents. The following is a basic permissive set of options:
//httpNodeCors: {
// origin: "*",
// methods: "GET,PUT,POST,DELETE"
// If you need to set an http proxy please set an environment variable
// called http_proxy (or HTTP_PROXY) outside of Node-RED in the operating system.
// For example - http_proxy=http://myproxy.com:8080
// (Setting it here will have no effect)
// You may also specify no_proxy (or NO_PROXY) to supply a comma separated
// list of domains to not proxy, eg - no_proxy=.acme.co,.acme.co.uk
// The following property can be used to add a custom middleware function
// in front of all http in nodes. This allows custom authentication to be
// applied to all http in nodes, or any other sort of common request processing.
//httpNodeMiddleware: function(req,res,next) {
// // Handle/reject the request, or pass it on to the http in node by calling next();
// // Optionally skip our rawBodyParser by setting this to true;
// //req.skipRawBodyParser = true;
// next();
// The following property can be used to pass custom options to the Express.js
// server used by Node-RED. For a full list of available options, refer
// to http://expressjs.com/en/api.html#app.settings.table
//httpServerOptions: { },
// The following property can be used to verify websocket connection attempts.
// This allows, for example, the HTTP request headers to be checked to ensure
// they include valid authentication information.
//webSocketNodeVerifyClient: function(info) {
// // 'info' has three properties:
// // - origin : the value in the Origin header
// // - req : the HTTP request
// // - secure : true if req.connection.authorized or req.connection.encrypted is set
// // The function should return true if the connection should be accepted, false otherwise.
// // Alternatively, if this function is defined to accept a second argument, callback,
// // it can be used to verify the client asynchronously.
// // The callback takes three arguments:
// // - result : boolean, whether to accept the connection or not
// // - code : if result is false, the HTTP error status to return
// // - reason: if result is false, the HTTP reason string to return
// The following property can be used to seed Global Context with predefined
// values. This allows extra node modules to be made available with the
// Function node.
// For example,
// functionGlobalContext: { os:require('os') }
// can be accessed in a function block as:
// global.get("os")
// os:require('os'),
// jfive:require("johnny-five"),
// j5board:require("johnny-five").Board({repl:false})
// `global.keys()` returns a list of all properties set in global context.
// This allows them to be displayed in the Context Sidebar within the editor.
// In some circumstances it is not desirable to expose them to the editor. The
// following property can be used to hide any property set in `functionGlobalContext`
// from being list by `global.keys()`.
// By default, the property is set to false to avoid accidental exposure of
// their values. Setting this to true will cause the keys to be listed.
exportGlobalContextKeys: false,
// Context Storage
// The following property can be used to enable context storage. The configuration
// provided here will enable file-based context that flushes to disk every 30 seconds.
// Refer to the documentation for further options: https://nodered.org/docs/api/context/
//contextStorage: {
// default: {
// module:"localfilesystem"
// The following property can be used to order the categories in the editor
// palette. If a node's category is not in the list, the category will get
// added to the end of the palette.
// If not set, the following default order is used:
//paletteCategories: ['subflows','flow','input','output','function','parser','social','mobile','storage','analysis','advanced'],
// Configure the logging output
logging: {
// Only console logging is currently supported
console: {
// Level of logging to be recorded. Options are:
// fatal - only those errors which make the application unusable should be recorded
// error - record errors which are deemed fatal for a particular request + fatal errors
// warn - record problems which are non fatal + errors + fatal errors
// info - record information about the general running of the application + warn + error + fatal errors
// debug - record information which is more verbose than info + info + warn + error + fatal errors
// trace - record very detailed logging + debug + info + warn + error + fatal errors
// off - turn off all logging (doesn't affect metrics or audit)
level: "info",
// Whether or not to include metric events in the log output
metrics: false,
// Whether or not to include audit events in the log output
audit: false
// Customising the editor
editorTheme: {
projects: {
// To enable the Projects feature, set this value to true
enabled: false
