Node-red on VMware ubuntu server websocket not working
Hi Everyone. i am running a ubuntu server version 20. Installerd node-red. The GUI is working en flows created. however im not able to create a websocket for instance with the samsung tv module. it gives me the error below:
27 Aug 17:02:09 - [info] Starting flows 27 Aug 17:02:09 - [info] Started flows 27 Aug 17:08:44 - [red] Uncaught Exception: 27 Aug 17:08:44 - Error: Error send Key at /home/user/.node-red/node_modules/samsung-tv-control/lib/samsung.js:55:23 at WebSocket. (/home/user/.node-red/node_modules/samsung-tv-control/lib/samsung.j s:289:17) at WebSocket.emit (events.js:400:28) at Receiver.receiverOnError (/home/user/.node-red/node_modules/ws/lib/websocket.js:951:13) at Receiver.emit (events.js:400:28) at emitErrorNT (internal/streams/destroy.js:106:8) at emitErrorCloseNT (internal/streams/destroy.js:74:3) at processTicksAndRejections (internal/process/task_queues.js:82:21) nodered.service: Main process exited, code=exited, status=1/FAILURE nodered.service: Failed with result 'exit-code'. nodered.service: Scheduled restart job, restart counter is at 6.
However when i run it from a windows machine the websocket is succesfully created.
Hi, this was asked and answered in github issues but to save anyone else looking into this...
The error is coming from a samsung-tv-control node.
My guess is the VM cannot reach your TV (network setup issue) and is crashing node-red. This is an issue with that node not correctly catching this error and you should raise an issue on the repository for the author to fix.
