Node-red read thousands of data from db with s7
Hello Community,
In my current project, I am reading thousands of data from plc db. For instance, i reads between 50-150 variables from just one db. Each variable is string[18]. I am connecting about 100 different db. 1005020 = 100,000 byte. This is how much byte i read inside 3-5seconds.
Sometimes i get timeout, our connreset or something like that. I want to optimize the way ı read from plc. I read about reading 1000bytes in single tag instead of using 50 different tag etc. But ı didnt find how can i do. What is your suggestion for my situation. What is the best way of reading thousands of bytes?
(I am using 1508S soft controller as plc)
You are overloading your driver with that amount of data. Options:
I found a simple and effective solutions for this. I convert the adress from DB10,S0.18 (if i read 20 tags i created 20 tag also like this DB10,S20.18 .... ) to DB10,S0.18.20 (.20 means read 20 variable from starting ofset. It solve my problem easiliy. After this, I can read 28 different db with just 3 connection. Critcal point is the variable you will read should be in a row. Currently, I can read every db every 500ms with timeout 1000ms. and It looks okay for now.
