Node-red repeat msg.payload in dashboard
Good evening,
I don't understand why.
Node-red repeat many times each msg.payload message in my dashbord.
eg:
Function
d = new Date()
p = msg.payload.event
i = msg.payload.nodeid
// t = msg.payload.uuid
/* t = msg.topic */
if(p===0 && i == "4"){
    o = "Porte fermée";
if(p===255 && i == "4"){
    o = "Porte ouverte";
if(p===0 && i == "9"){
    o = "Aucun liquide detecte";
if(p===255 && i == "9"){
    o = "Liquide detecte";
msg.payload = o + " " + d;
return msg
And the result in Dashboard is:
Somebody could help me ?
Thank you
Add a debug to your zwave node to check that you aren’t getting duplicate messages.
You can also give your debug nodes a name to make it easier to see where they are coming from.
you're right..
Give..
If you change the debug to display the complete message object you should be able to filter the messages based on msg.topic and part of the msg.payload.object using switch nodes
If they are exact duplicates then the RBE node will remove the extra ones for you.
Thank you ukmoose and dceejay for your help, it's appreciate
ukmoose:
I tried that, but msg.topic and msg.payload.object seem to be identical between the detector of open/close door and the detector of water.
dceejay
Good suggestion, i didn't know that, but I have found another solution that seem to work.
I modified my function like:
d = new Date()
o = "Porte fermée le " + d;
msg.payload = o;
o = "Porte ouverte le " + d;
msg.payload = o;
o = "Aucun liquide detecte le " + d;
msg.payload = o;
o = "Liquide detecte " + d;
msg.payload = o;
And it works well :wink:
