yeaaaaah... guilty
I suggest using the recommended script to update node-red. Ditch pm2 and use the provided systemd scripts that you get with the script. Then you will have a conventional setup and we will have a much better chance of working out what is going on, if you still have a problem. I would not be surprised if it is pm2 that is causing the problem.
