Node-Red save to Postgres
I have a flow that received mqtt and save to postgres using re-postgres. Here's my flow.
        "id": "03a53e00c9c78103",
        "type": "function",
        "z": "14ee6d7566a42e0e",
        "name": "function 3",
        "func": "var topic1 = msg.topic;\nvar payload1 = JSON.stringify(msg.payload);\nmsg.payload = \"INSERT INTO public.mqtt_table (id, topic, payload) VALUES ('1','\" + topic1 + \"','\" + payload1 + \"');\";\n// Return the modified message\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 220,
                "83d4b160a599297a"
        "id": "3095d062c0825ec3",
        "type": "mqtt in",
        "topic": "data",
        "qos": "2",
        "datatype": "json",
        "broker": "bc8faf152aa409d6",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 190,
        "y": 220,
                "e3844ce7e1b2ac9a"
        "id": "e3844ce7e1b2ac9a",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 390,
        "y": 220,
                "03a53e00c9c78103"
        "id": "fd9a8caa5b0109b9",
        "type": "postgres",
        "postgresdb": "6d425120c2df7839",
        "name": "db",
        "output": true,
        "perrow": false,
        "return_on_error": false,
        "limit_drop_intermediate": false,
        "limit_drop_if_in_queue": false,
        "outputs": true,
        "x": 930,
        "y": 220,
        "id": "83d4b160a599297a",
        "type": "function",
        "name": "function 7",
        "func": "msg.queryParameters = msg.payload;\nconsole.log(msg.queryParameters)\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 220,
                "fd9a8caa5b0109b9"
        "id": "bc8faf152aa409d6",
        "type": "mqtt-broker",
        "name": "broker",
        "broker": "localhost",
        "port": "1884",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "6d425120c2df7839",
        "type": "postgresdb",
        "hostname": "localhost",
        "port": "5432",
        "db": "users",
        "ssl": false
Here is my sample mqtt data
    "key": "pumpingstation",
    "value": "0.00"
    "key": "centrifuge",
    "value": "21.08"
    "key": "Dafpump1",
    "value": "5.20"
    "key": "Dafpump2",
    "value": "23.10"
I have tried my query to the query tool of pgAdmin and it's working but in my flow it's not. What's wrong?
Have you read the built-in help for the postgres node? Some nodes expect the SQL to be in topic. Some nodes expect the SQL to be in payload.
The postgres node expects sql to be in msg.query
Also, there are multiple postgres nodes in the palette manager, the only one I've found to work reliably is
"node-red-contrib-postgresql"
hello. So I switched to node-red-contrib-postgrestor-next and It's actually working but for some reason I have a problem in json format. I have a posgres column that is jsonb and when I tried to deploy I encounter an error it says "error: invalid input syntax for type json"
my json data is a valid json I already checked that:
[{"key":"pumpingstation","value":"0.00"},{"key":"centrifuge","value":"2.2"},{"key":"Dafpump1","value":"5.01"},{"key":"Dafpump2","value":"22.69"}]
and in my postgres node query I have:
INSERT INTO public.mqtt_table (data, created_at, created_time, created_date)
VALUES ('{{msg.payload}}', '{{msg.timestamp}}', '{{msg.time}}', '{{msg.date}}');
The error exist in msg.payload. I have a function before my postgres node:
var input = msg.payload
// Split the input string into key-value pairs
var pairs = input.split(",");
// Initialize an array to store the JSON objects
var output = [];
// Loop through each key-value pair
for (var i = 0; i < pairs.length; i++) {
    // Split the pair into key and value
    var parts = pairs[i].split(" ");
    // Create a JSON object with the key and value
    var obj = {
        "key": parts[0],
        "value": parts[1]
    // Add the object to the output array
    output.push(obj);
var currentDate = new Date();
var date = currentDate.getFullYear() + "-" + (currentDate.getMonth() + 1) + "-" + currentDate.getDate();
var time = currentDate.getHours() + ":" + currentDate.getMinutes() + ":" + currentDate.getSeconds() + "." + currentDate.getMilliseconds();
msg.date = date;
msg.time = time;
msg.payload = JSON.stringify(output);
msg.timestamp = new Date().toISOString();
for my flow I included it below.
        "id": "14ee6d7566a42e0e",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "d7befe8c4eedf592",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "460f2b8f.a23dbc",
        "type": "tab",
        "label": "Postgres example flows",
        "disabled": false,
        "info": "# Postgres example flows\n\nThese flows demonstrate the use of the\n`node-red-contrib-postgres-multi` node.\n\n## Setup\n\nFor the flows in this tab,\nyou'll need a PostgreSQL table like so:\n\n    begin;\n    create table mytable\n    (\n        id integer not null,\n        message character varying(20)\n    );\n    create unique index on mytable (id);\n    commit;\n\nThen you'll need to configure the postgres\nblocks to have access to this database and table.\n"
        "id": "48acf0a74b57fcc9",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": ""
        "id": "39b7a323071521ea",
        "type": "tab",
        "label": "Flow 5",
        "disabled": false,
        "info": ""
        "name": "broker",
        "port": "1884",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "e0ddc1469372b4eb",
        "type": "postgresDB",
        "name": "postgres@127.0.0.1:5432/users",
        "host": "127.0.0.1",
        "hostFieldType": "str",
        "port": "5432",
        "portFieldType": "num",
        "database": "users",
        "databaseFieldType": "str",
        "ssl": "false",
        "sslFieldType": "bool",
        "max": "10",
        "maxFieldType": "num",
        "min": "1",
        "minFieldType": "num",
        "idle": "1000",
        "idleFieldType": "num",
        "connectionTimeout": "10000",
        "connectionTimeoutFieldType": "num",
        "user": "postgres",
        "userFieldType": "str",
        "password": "postgres",
        "passwordFieldType": "str"
        "type": "mqtt in",
        "topic": "data",
        "qos": "0",
        "datatype": "utf8",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 190,
        "y": 220,
                "e3844ce7e1b2ac9a"
        "id": "e151017ec914297c",
        "type": "postgrestor",
        "query": "INSERT INTO public.mqtt_table (data, created_at, created_time, created_date) \nVALUES ('\"{{msg.payload}}\"', '{{msg.timestamp}}', '{{msg.time}}', '{{msg.date}}');",
        "postgresDB": "e0ddc1469372b4eb",
        "output": true,
        "outputs": 1,
        "x": 870,
        "y": 220,
                "32e561ec20b60389"
        "id": "1f82b28cc4ca2366",
        "type": "mqtt out",
        "topic": "data",
        "qos": "1",
        "retain": "true",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1110,
        "y": 460,
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 350,
        "y": 220,
                "0111a731629934cf"
        "id": "0111a731629934cf",
        "type": "function",
        "func": "if (msg.payload.search('pumping station') != -1) msg.payload = msg.payload.replace('pumping station', 'pumpingstation')\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 520,
        "y": 220,
                "871d89e7315bfc39"
        "id": "871d89e7315bfc39",
        "type": "function",
        "name": "function 8",
        "func": "var input = msg.payload\n\n// Split the input string into key-value pairs\nvar pairs = input.split(\",\");\n\n// Initialize an array to store the JSON objects\nvar output = [];\n\n// Loop through each key-value pair\nfor (var i = 0; i < pairs.length; i++) {\n    // Split the pair into key and value\n    var parts = pairs[i].split(\" \");\n\n    // Create a JSON object with the key and value\n    var obj = {\n        \"key\": parts[0],\n        \"value\": parts[1]\n    };\n\n    // Add the object to the output array\n    output.push(obj);\n}\n\nvar currentDate = new Date();\nvar date = currentDate.getFullYear() + \"-\" + (currentDate.getMonth() + 1) + \"-\" + currentDate.getDate();\nvar time = currentDate.getHours() + \":\" + currentDate.getMinutes() + \":\" + currentDate.getSeconds() + \".\" + currentDate.getMilliseconds();\n\nmsg.date = date;\nmsg.time = time;\nmsg.payload = JSON.stringify(output);\nmsg.timestamp = new Date().toISOString();\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 220,
                "e151017ec914297c",
                "32e561ec20b60389"
        "id": "32e561ec20b60389",
        "type": "debug",
        "name": "debug 6",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1050,
        "y": 120,
        "id": "e9a9a2e8.4f4ca",
        "type": "inject",
        "z": "d7befe8c4eedf592",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "data",
        "payload": "[{\"key\":\"pumpingstation\",\"value\":\"0.00\"},{\"key\":\"centrifuge\",\"value\":\"21.08\"},{\"key\":\"Dafpump1\",\"value\":\"5.20\"},{\"key\":\"Dafpump2\",\"value\":\"23.10\"}]",
        "payloadType": "json",
        "x": 350,
        "y": 340,
                "bf8fa5f5.5b7e5"
        "id": "bf8fa5f5.5b7e5",
        "type": "function",
        "name": "Insert into postgresql",
        "func": "var topic1 = msg.topic;\nvar payload1 = JSON.stringify(msg.payload);\n\nmsg.payload = [{\n    query: \"insert into mqtt_table (topic) values ('data')\",\n    params: [topic1]\n}];\n// Return the modified message\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 630,
        "y": 340,
        "id": "fdab0152a508eee2",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "statusVal": "",
        "x": 930,
        "y": 220,
        "id": "5498d534.e9cc54",
        "type": "comment",
        "z": "460f2b8f.a23dbc",
        "name": "Reset",
        "info": "This flow clears any contents from\nthe `mytable` table and inserts a single\nrecord:\n\n    id   message\n    1    'hello world'\n",
        "x": 90,
        "y": 40,
        "id": "2ef9ce55.1ee282",
        "type": "inject",
        "name": "click me",
        "repeat": "",
        "crontab": "",
        "once": false,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 100,
                "98595979.a97fe"
        "id": "98595979.a97fe",
        "type": "function",
        "name": "prepare",
        "func": "\nmsg.payload = [\n    {\n        query: 'begin',\n    },\n    {\n        query: 'delete from mytable',\n    },\n    {\n        query: 'insert into mytable (id, message) values ($1, $2)',\n        params: [1, 'hello world'],\n    },\n    {\n        query: 'select * from mytable',\n        output: true,\n    },\n    {\n        query: 'commit',\n    },\n];\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 300,
        "y": 100,
        "id": "87793132.0d9d88",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": false,
        "statusVal": "",
        "x": 689.5,
        "y": 100,
        "id": "27e47fba.f5896",
        "type": "comment",
        "name": "Demo",
        "info": "This flow demonstrates:\n\n* transactions and auto-commit queries\n* positional arguments (i.e. $argName)\n* query output from multiple queries\n",
        "x": 90,
        "y": 180,
        "id": "2de05c89.ff8454",
        "type": "inject",
        "name": "click me",
        "repeat": "",
        "crontab": "",
        "once": false,
        "topic": "",
        "payload": "",
        "x": 120,
        "y": 240,
                "b5127483.4ae8d8"
        "id": "b5127483.4ae8d8",
        "type": "function",
        "name": "prepare",
        "func": "\nmsg.payload = [\n    {\n        query: 'begin',\n    },\n    {\n        query: 'delete from mytable',\n    },\n    {\n        query:\n            'insert into mytable (id, message) ' +\n            'values ($foo, $bar), ($baz, $boop)',\n        params: {\n            foo: 10,\n            bar: 'hello',\n            baz: 20,\n            boop: 'world',\n        },\n    },\n    {\n        query: 'commit',\n    },\n    {\n        query: 'select * from mytable',\n        output: true,\n    },\n    {\n        query: 'insert into mytable (id, message) values (30, \\'xtra\\')',\n    },\n    {\n        query: 'select message from mytable order by id',\n        output: true,\n    },\n];\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 300,
        "y": 240,
        "id": "68797b5f.c0a3ec",
        "type": "debug",
        "active": true,
        "console": "false",
        "complete": "false",
        "x": 679.5,
        "y": 240,
        "id": "35f6d8a5.a36018",
        "type": "comment",
        "name": "Rollback",
        "info": "If you start a transaction and don't commit it,\nyour changes will not be saved.",
        "x": 100,
        "y": 320,
        "id": "ba356a1b.b7c2e8",
        "type": "inject",
        "name": "click me",
        "repeat": "",
        "crontab": "",
        "once": false,
        "topic": "",
        "payload": "",
        "x": 120,
        "y": 380,
                "73628965.7539d8"
        "id": "73628965.7539d8",
        "type": "function",
        "name": "prepare",
        "func": "\nmsg.payload = [\n    {\n        query: 'begin',\n    },\n    {\n        query: 'delete from mytable',\n    },\n    {\n        query:\n            'insert into mytable (id, message) ' +\n            'values ($foo, $bar), ($baz, $boop), ($bing, $bang)',\n        params: {\n            foo: 10,\n            bar: 'one does not simply',\n            baz: 20,\n            boop: 'begin',\n            bing: 30,\n            bang: 'but not commit',\n        },\n    },\n    {\n        query: 'select message from mytable order by id',\n        output: true,\n    },\n];\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 300,
        "y": 380,
        "id": "77248a23.6a48b4",
        "type": "debug",
        "active": true,
        "console": "false",
        "x": 679.5,
        "y": 380,
        "id": "b5a1d7d5.4301a8",
        "type": "function",
        "name": "check",
        "func": "\nmsg.payload = [\n    {\n        query: 'select message from mytable order by id',\n        output: true,\n    },\n];\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 290,
        "y": 460,
        "id": "b0f96526.7a4648",
        "type": "debug",
        "active": true,
        "console": "false",
        "x": 679.5,
        "y": 460,
        "id": "d529a78a2e573d90",
        "type": "inject",
        "z": "48acf0a74b57fcc9",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 120,
                "e07778d9b2c8fb02"
        "id": "20cc6b5c533c30e6",
        "type": "function",
        "name": "Write to PostgreSQL",
        "func": "var a = global.get('value1');\nvar b = global.get('value2');\nvar c = global.get('value3');\nvar now = new Date().toLocaleString(\"DE\");\n\nmsg.payload = \"INSERT INTO mqtt_table (topic) VALUES (\"+a+\");\"\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 580,
        "y": 320,
                "f5e2c8b9af25420c"
        "id": "f5e2c8b9af25420c",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 750,
        "y": 60,
        "id": "e07778d9b2c8fb02",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 370,
        "y": 320,
                "20cc6b5c533c30e6"
        "id": "7c7d587c0fb0613f",
        "type": "inject",
        "z": "39b7a323071521ea",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 120,
                "280df0e833b808c0"
        "id": "04d4d7e472ea72e8",
        "type": "comment",
        "name": "Read from PLC",
        "info": "",
        "x": 140,
        "y": 40,
        "id": "313ea4faad2b4e26",
        "type": "function",
        "func": "var a = global.get('value1');\nvar b = global.get('value2');\nvar c = global.get('value3');\nvar now = new Date().toLocaleString(\"DE\");\n\nmsg.payload = \"INSERT INTO temperature (topic) VALUES (\"+a+\");\"\nreturn msg;\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 580,
        "y": 320,
                "00165a9a8befdf68"
        "id": "00165a9a8befdf68",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 750,
        "y": 60,
        "id": "280df0e833b808c0",
        "type": "delay",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 370,
        "y": 320,
                "313ea4faad2b4e26"
        "id": "c18f0b430ab15f63",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1010,
        "y": 320,
        "id": "8764ea0ccc24c421",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
                "p": "speed1",
                "v": "50",
                "vt": "str"
                "p": "speed2",
                "v": "60",
                "vt": "str"
                "p": "speed3",
                "v": "70",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 370,
        "y": 440,
        "id": "260cca63ad6725d4",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": true,
        "tostatus": true,
        "complete": "true",
        "targetType": "full",
        "statusVal": "payload",
        "x": 710,
        "y": 440,
flows (1).json (5.0 KB)
I had tried node-red-contrib-postgrestor-next, but switched to node-red-contrib-postgresql, the main reason being I got fed up trying to insert json into a postgres column, just like you want to do.
I'm sure it's possible with postgrestor-next, but since it works great with the node-red-contrib-postgresql node I had no reason to go back.
If you decide to try node-red-contrib-postgresql, the only thing you would want to change is use 3 curly braces instead of 2; e.g. '{{{msg.payload}}}'
Your function node looks good.
Also you could try switching your postgres jsonb column to json, jsonb is a little more compact (removes line wraps), but it could be that you would need to insert it differently.
