Firstly, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
As for sending image from Nas, you essentially replace the http request with whatever means you have of grabbing the image from the Nas. E.g. a file in node will read a file and return a buffer. Give it a go. Use a debug node to check the file in node reads a buffer of bytes.
