Node Red textarea with template node" No msg.payload input possible after changing content of textarea"
The attached Node Red Flow with the attached HTML and Javascript Code is working as follows:
  1. msg.payload sending from the buttons is displayed in the textarea and can also be send out correct to the debug node
  2. I also can change the content of the textarea and then send out correct to the debug node
    But after I have changed the content of the textarea, all further msg.payload inputs from the Buttons are ignored until I make re deployment of Node Red.
Content of Textarea Node
 <textarea name="textentered" id="textentered" rows="8" cols="25">{{msg.payload}}</textarea>
      <input type="submit" value="Save Comments" ng-click="send({payload:test()})">
<script>
(function(scope) {
    scope.test = function() {
        var text = document.getElementById("textentered").value;
        alert(text);
        return "E:"+text;
})(scope)
</script>
I have made several modification but never could fix this problem. So I hope somebody in this community can help me.
[{"id":"284cd852.c67658","type":"tab","label":"Test Textarea","disabled":false,"info":""},{"id":"8e7a3e8e.4c077","type":"ui_button","z":"284cd852.c67658","name":"Input \"Test Text\"","group":"67a39dee.c646e4","order":1,"width":"3","height":"1","passthru":false,"label":"Test Text","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"TestText","payloadType":"str","topic":"","topicType":"str","x":210,"y":320,"wires":[["2eff8061.69559"]]},{"id":"fae42a25.a6e348","type":"ui_button","z":"284cd852.c67658","name":"Input \"\"","group":"67a39dee.c646e4","order":2,"width":"3","height":"1","passthru":false,"label":"^^","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":" ","payloadType":"str","topic":"","topicType":"str","x":180,"y":380,"wires":[["2eff8061.69559"]]},{"id":"53d4f9b7.899c88","type":"debug","z":"284cd852.c67658","name":"Content of textarea","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":710,"y":380,"wires":[]},{"id":"2eff8061.69559","type":"ui_template","z":"284cd852.c67658","group":"67a39dee.c646e4","name":"Textarea","order":3,"width":"0","height":"0","format":"      <textarea name=\"textentered\" id=\"textentered\" rows=\"8\" cols=\"25\">{{msg.payload}}</textarea>\n      <input type=\"submit\" value=\"Save Comments\" ng-click=\"send({payload:test()})\">\n      \n<script>\n\n(function(scope) {\n\n    scope.test = function() {\n \n        var text = document.getElementById(\"textentered\").value;\n        alert(text);\n        return \"E:\"+text;\n    }\n\n    \n})(scope)\n\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":500,"y":380,"wires":[["53d4f9b7.899c88"]]},{"id":"67a39dee.c646e4","type":"ui_group","name":"Date Range","tab":"660a703d.ea902","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"660a703d.ea902","type":"ui_tab","name":"Test Multiline Input","icon":"fa-bar-chart","order":4,"disabled":false,"hidden":false}]
I now alone have found the solution. Problem: HTML code for Dashboard already had the new msg.payload, but Dashboard was not refreshed.
With Dashboard refresh nodes at each msg.input it works fine !!!
You can always just write to the document element.
      <textarea name="textentered" id="textentered"  rows="8" cols="25">No message received</textarea>
      <input type="submit" value="Save Comments" ng-click="test()">
<script>
(function(scope) {
  const element = document.getElementById("textentered");
    if (msg.payload) {
      // Do something when msg arrives
      element.value = msg.payload;
        var text = element.value;
        scope.send({payload: "E:"+text});
})(scope)
</script>
example flow
[{"id":"8e7a3e8e.4c077","type":"ui_button","z":"284cd852.c67658","name":"Input \"Test Text\"","group":"67a39dee.c646e4","order":1,"width":"3","height":"1","passthru":false,"label":"Test Text","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"TestText","payloadType":"str","topic":"","topicType":"str","x":160,"y":320,"wires":[["2eff8061.69559","907e4fabb15681e7"]]},{"id":"2eff8061.69559","type":"ui_template","z":"284cd852.c67658","group":"67a39dee.c646e4","name":"Textarea","order":3,"width":"0","height":"0","format":"      <textarea name=\"textentered\" id=\"textentered\"  rows=\"8\" cols=\"25\">No message received</textarea>\n      <input type=\"submit\" value=\"Save Comments\" ng-click=\"test()\">\n      \n<script>\n\n(function(scope) {\n  const element = document.getElementById(\"textentered\");\n  \n  scope.$watch('msg', function(msg) {\n    if (msg.payload) {\n      // Do something when msg arrives\n      element.value = msg.payload;\n    }\n  })\n  \n  scope.test = function() {\n        var text = element.value;\n        scope.send({payload: \"E:\"+text});\n    }\n})(scope)\n\n</script>\n","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":450,"y":380,"wires":[["53d4f9b7.899c88"]]},{"id":"fae42a25.a6e348","type":"ui_button","z":"284cd852.c67658","name":"Input \"\"","group":"67a39dee.c646e4","order":2,"width":"3","height":"1","passthru":false,"label":"^^","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":" ","payloadType":"str","topic":"","topicType":"str","x":130,"y":380,"wires":[["2eff8061.69559"]]},{"id":"53d4f9b7.899c88","type":"debug","z":"284cd852.c67658","name":"Content of textarea","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":660,"y":380,"wires":[]},{"id":"67a39dee.c646e4","type":"ui_group","name":"Date Range","tab":"660a703d.ea902","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"660a703d.ea902","type":"ui_tab","name":"Test Multiline Input","icon":"fa-bar-chart","order":4,"disabled":false,"hidden":false}]
No refresh required.
Perfect this also works and is much easier.
Many thanks.
