Node red ui builder with jquery?
I try to use jquery code inside my index.js file (using node red contrib uibuilder).
But I always get an error if i use code like this: $('#container').hide();
The browser shows me: "Uncaught ReferenceError: $ is not defined".
I found an jquery example flow jquery example
But there is now juqery code inside the index.js file.
Is there no way to use jquery or what am I doing wrong?
Thanks, Tom
I found the problem :wink:
I forgot to implement the jquery script file inside the index.html.
