Hallo all,
node-Red runs in a Docker container on the Plc Next F 2152.
I am currently facing the problem that I would like to save CSV files on my PLC via Node-Red. Unfortunately, this controller currently refuses to execute Node-RED mkdir commands. Do you have any idea how I can give permission in Node-Red to create/modify/overwrite/delete files under a certain path at any time?
My Nodes ->
[{"id":"687306f9.a916a","type":"file","z":"f6f2187d.f17ca8","name":"","filename":"/opt/plcnext/logger.csv","appendNewline":true,"createDir":true,"overwriteFile":"true","encoding":"none","x":960,"y":100,"wires":[]},{"id":"91881442.f40e2","type":"inject","z":"f6f2187d.f17ca8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":270,"y":100,"wires":[["6fae87cc.d45538"]]},{"id":"6fae87cc.d45538","type":"function","z":"f6f2187d.f17ca8","name":"","func":"var capa = flow.get("capa") || 0;\nflow.set ("ccapa_Ah",capa);\n\nreturn {payload:"Kapazität in Ah;Kapa"};","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":100,"wires":[["6b721786.23fa1","687306f9.a916a"]]},{"id":"6b721786.23fa1","type":"debug","z":"f6f2187d.f17ca8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":40,"wires":}]
