Node-Red Virtual Keyboard Display issue
Hi
I am using this Virtual Keyboard in a small raspberry pi embedded project, with a 5" touch display. It seems since a chrome browser update it no longer displays correctly on a small screen.
I suspect it is fixable by applying the right CSS, but all my efforts have failed so far (I'm not a CSS pro :roll_eyes:)
If someone could help me out it would be awesome. To test simply resize your browser window, the keyboard should ideally remain at full width at all times.
Also would like to thank @hugobox for originally adapting it to work in a ui-template.
UI template code:
<script>
// the semi-colon before function invocation is a safety net against concatenated
// scripts and/or other plugins which may not be closed properly.
; (function ($, window, document, undefined) {
    // undefined is used here as the undefined global variable in ECMAScript 3 is
    // mutable (ie. it can be changed by someone else). undefined isn't really being
    // passed in so we can ensure the value of it is truly undefined. In ES5, undefined
    // can no longer be modified.
    // window and document are passed through as local variable rather than global
    // as this (slightly) quickens the resolution process and can be more efficiently
    // minified (especially when both are regularly referenced in your plugin).
    // Create the defaults once
    var pluginName = "jkeyboard",
        defaults = {
            layout: "english",
            input: $('#input'),
            customLayouts: {
                selectable: []
    var function_keys = {
        backspace: {
            text: 'DEL',
        return: {
            text: 'Enter'
        shift: {
            text: 'Shift'
        space: {
            text: 'Space'
        numeric_switch: {
            text: '123',
            command: function () {
                this.createKeyboard('numeric');
                this.events();
        layout_switch: {
            text: '<i class="fa fa-keyboard-o" aria-hidden="true"></i>',
                var l = this.toggleLayout();
                this.createKeyboard(l);
                this.events();
        character_switch: {
            text: 'ABC',
                this.createKeyboard(layout);
                this.events();
        symbol_switch: {
            text: '#+=',
                this.createKeyboard('symbolic');
                this.events();
    var layouts = {
        selectable: ['azeri', 'english', 'russian','french', 'emoji'],
        azeri: [
            ['q', 'ü', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p', 'ö', 'ğ'],
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l', 'ı', 'ə'],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm', 'ç', 'ş', 'backspace'],
            ['numeric_switch', 'layout_switch', 'space', 'return']
        english: [
            ['q', 'w', 'e', 'r', 't', 'y', 'u', 'i', 'o', 'p',],
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l',],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm', 'backspace'],
        russian: [
            ['й', 'ц', 'у', 'к', 'е', 'н', 'г', 'ш', 'щ', 'з', 'х'],
            ['ф', 'ы', 'в', 'а', 'п', 'р', 'о', 'л', 'д', 'ж', 'э'],
            ['shift', 'я', 'ч', 'с', 'м', 'и', 'т', 'ь', 'б', 'ю', 'backspace'],
        french: [
            ['a', 's', 'd', 'f', 'g', 'h', 'j', 'k', 'l','à','ç'],
            ['shift', 'z', 'x', 'c', 'v', 'b', 'n', 'm','é','è', 'backspace'],
        emoji: [
            ['😋', '😎', '😍', '😘', 'g', 'h', 'j', 'k', 'l','à','ç'],
        numeric: [
            ['1', '2', '3', '4', '5', '6', '7', '8', '9', '0'],
            ['symbol_switch', '.', ',', '?', '!', "'", 'backspace'],
            ['character_switch', 'layout_switch', 'space', 'return'],
        numbers_only: [
            ['1', '2', '3',],
            ['4', '5', '6',],
            ['7', '8', '9',],
            ['0', 'backspace', 'return'],
        symbolic: [
            ['_', '\\', '|', '~', '<', '>'],
            ['numeric_switch', '.', ',', '?', '!', "'", 'backspace'],
    var shift = false, capslock = false, layout = 'english', layout_id = 0;
    // The actual plugin constructor
    function Plugin(element, options) {
        this.element = element;
        // jQuery has an extend method which merges the contents of two or
        // more objects, storing the result in the first object. The first object
        // is generally empty as we don't want to alter the default options for
        // future instances of the plugin
        this.settings = $.extend({}, defaults, options);
        // Extend & Merge the cusom layouts
        layouts = $.extend(true, {}, this.settings.customLayouts, layouts);
        if (Array.isArray(this.settings.customLayouts.selectable)) {
            $.merge(layouts.selectable, this.settings.customLayouts.selectable);
        this._defaults = defaults;
        this._name = pluginName;
        this.init();
    Plugin.prototype = {
        init: function () {
            layout = this.settings.layout;
            this.events();
        setInput: function (newInputField) {
            this.settings.input = newInputField;
        createKeyboard: function (layout) {
            shift = false;
            capslock = false;
            var keyboard_container = $('<ul/>').addClass('jkeyboard'),
                me = this;
            layouts[layout].forEach(function (line, index) {
                var line_container = $('<li/>').addClass('jline');
                line_container.append(me.createLine(line));
                keyboard_container.append(line_container);
            $(this.element).html('').append(keyboard_container);
        createLine: function (line) {
            var line_container = $('<ul/>');
            line.forEach(function (key, index) {
                var key_container = $('<li/>').addClass('jkey').data('command', key);
                if (function_keys[key]) {
                    key_container.addClass(key).html(function_keys[key].text);
                else {
                    key_container.addClass('letter').html(key);
                line_container.append(key_container);
            return line_container;
        events: function () {
            var letters = $(this.element).find('.letter'),
                shift_key = $(this.element).find('.shift'),
                space_key = $(this.element).find('.space'),
                backspace_key = $(this.element).find('.backspace'),
                return_key = $(this.element).find('.return'),
                me = this,
                fkeys = Object.keys(function_keys).map(function (k) {
                    return '.' + k;
                }).join(',');
            letters.on('click', function () {
                me.type((shift || capslock) ? $(this).text().toUpperCase() : $(this).text());
            space_key.on('click', function () {
                me.type(' ');
            return_key.on('click', function () {
                me.enter();
            backspace_key.on('click', function () {
                me.backspace();
            shift_key.on('click', function () {
                if (capslock) {
                    me.toggleShiftOff();
                    capslock = false;
                } else {
                    me.toggleShiftOn();
            }).on('dblclick', function () {
                capslock = true;
            $(fkeys).on('click', function () {
                var command = function_keys[$(this).data('command')].command;
                if (!command) return;
                command.call(me);
        type: function (key) {
            var input = this.settings.input,
                val = input.val(),
                input_node = input.get(0),
                start = input_node.selectionStart,
                end = input_node.selectionEnd;
            var max_length = $(input).attr("maxlength");
            if (start == end && end == val.length) {
                if (!max_length || val.length < max_length) {
                    input.val(val + key);
                    input.change()
                    $('#vkeyname').text(val + key)
            } else {
                if (input_node.type == "text"){
                    var new_string = this.insertToString(start, end, val, key);
                    input.val(new_string);
                    start++;
                    end = start;
                    input_node.setSelectionRange(start, end);
                    input.change()
                }else if (input_node.type == "number"){
                }else{
                    input.change()
            input.trigger('focus');
            if (shift && !capslock) {
                this.toggleShiftOff();
        enter: function () {
                val = input.val();
            if (input.type == "text"){
                val = val + "\n";
                $('#vkeyname').text(val)
            input.change()
            input.focus()
        backspace: function () {
                val = input.val();
                input.val(val.slice(0, start-1) + val.slice(start))
                input_node.setSelectionRange(start-1, start-1);
                //console.log(val)
            }else{
                input.val(val.slice(0,-1))
                $('#vkeyname').text(val.slice(0,-1))
            input.change()
            //input.focus()
        toggleShiftOn: function () {
                shift_key = $(this.element).find('.shift');
            letters.addClass('uppercase');
            shift_key.addClass('active')
            shift = true;
        toggleShiftOff: function () {
            letters.removeClass('uppercase');
            shift_key.removeClass('active');
            shift = false;
        toggleLayout: function () {
            layout_id = layout_id || 0;
            var plain_layouts = layouts.selectable;
            layout_id++;
            var current_id = layout_id % plain_layouts.length;
            var SelectedLayoutName = plain_layouts[current_id];
            $('#vkeyname').text('V-Keyboard ' + SelectedLayoutName )
            return plain_layouts[current_id];
        insertToString: function (start, end, string, insert_string) {
            return string.substring(0, start) + insert_string + string.substring(end, string.length);
		// A really lightweight plugin wrapper around the constructor,
		// preventing against multiple instantiations
		$.fn[ pluginName ] = function ( options ) {
				return this.each(function() {
						if ( !$.data( this, "plugin_" + pluginName ) ) {
								$.data( this, "plugin_" + pluginName, new Plugin( this, options ) );
        var methods = {
            init: function(options) {
                if (!this.data("plugin_" + pluginName)) {
                    this.data("plugin_" + pluginName, new Plugin(this, options));
			setInput: function(content) {
				this.data("plugin_" + pluginName).setInput($(content));
            setLayout: function(layoutname) {
                // change layout if it is not match current
                object = this.data("plugin_" + pluginName);
                if (typeof(layouts[layoutname]) !== 'undefined' && object.settings.layout != layoutname) {
                    object.settings.layout = layoutname;
                    object.createKeyboard(layoutname);
                    object.events();
		$.fn[pluginName] = function (methodOrOptions) {
            if (methods[methodOrOptions]) {
                return methods[methodOrOptions].apply(this.first(), Array.prototype.slice.call( arguments, 1));
            } else if (typeof methodOrOptions === 'object' || ! methodOrOptions) {
                // Default to "init"
                return methods.init.apply(this.first(), arguments);
            } else {
                $.error('Method ' +  methodOrOptions + ' does not exist on jQuery.tooltip');
})(jQuery, window, document);
</script>
<style>
    .jkeyboard {
  display: inline-block;
.jkeyboard, .jkeyboard .jline, .jkeyboard .jline ul {
  display: block;
  margin: 0;
  padding: 0;
.jkeyboard .jline {
  text-align: center;
  margin-left: -14px;
.jkeyboard .jline ul li {
  font-family: arial, sans-serif;
  font-size: 20px;
  border: 1px solid #468db3;
  -webkit-box-shadow: 0 0 3px #468db3;
  -webkit-box-shadow: inset 0 0 3px #468db3;
  margin: 5px 0 1px 6px;
  color: #000000;
  border-radius: 5px;
  width: 52px;
  height: 52px;
  box-sizing: border-box;
  text-align: center;
  line-height: 52px;
  overflow: hidden;
  cursor: pointer;
  -webkit-touch-callout: none;
  -webkit-user-select: none;
  -khtml-user-select: none;
  -moz-user-select: -moz-none;
  -ms-user-select: none;
  user-select: none;
.jkeyboard .jline ul li.uppercase {
  text-transform: uppercase;
.jkeyboard .jline ul li:hover, .jkeyboard .jline ul li:active {
  background-color: #185a82;
.jkeyboard .jline .return {
  width: 80px;
.jkeyboard .jline .space {
  width: 366px;
.jkeyboard .jline .numeric_switch {
  width: 65px;
.jkeyboard .jline .layout_switch {
.jkeyboard .jline .shift {
  width: 60px;
.jkeyboard .jline .backspace {
  width: 69px;
</style>
<style>
body {font-family: Arial, Helvetica, sans-serif;}
.nr-dashboard-theme .nr-dashboard-template .md-button:not(:first-of-type) {
    margin-top: 0px;
/* The Modal (background) */
.modal {
    display: none; /* Hidden by default */
    position: fixed; /* Stay in place */
    opacity:0.99;
    z-index: 100; /* Sit on top */
    left: 0;
    top: 0;
    width: 100%; /* Full width */
    height: 100%; /* Full height */
    overflow: auto; /* Enable scroll if needed */
    background-color: rgb(0,0,0); /* Fallback color */
    background-color: rgba(0,0,0,0.4); /* Black w/ opacity */
/* Modal Content */
.modal-content {
    position: fixed;
    background-color: #fefefe;
    margin: auto;
    padding: 0;
    bottom: 0%;
    left: 50%;
    transform: translate(-50%, 0%);
    border: 1px solid #888;
    width: fit-content;
    max-width: 100%;
    max-height: 100%;
    box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);
    -webkit-animation-name: animate;
    -webkit-animation-duration: 0.4s;
/* Add Animation */
@-webkit-keyframes animate {
    from {bottom:100%; opacity:0}
    to {bottom:0%; opacity:1}
@keyframes animate {
/* The Close Button */
.close {
    color: black;
    float: right;
    font-size: 28px;
    font-weight: bold;
.close:hover,
.close:focus {
    color: #000;
    text-decoration: none;
    cursor: pointer;
.modal-header {
    padding: 2px 16px;
    background-color: aliceblue;
    color: white;
.modal-body {padding: 2px 16px;}
.modal-footer {
    padding: 2px 16px;
    background-color: #5cb85c;
    color: white;
</style>
<!-- The Modal -->
<div id="myModal" class="modal">
  <!-- Modal content -->
  <div class="modal-content">
      <div class="modal-header">
      <span class="close" onclick="closeModal()">&times;</span>
      <h2 id="vkeyname" style="background-color: aliceblue !important; color: black !important; text-align: center; min-height: 30px;">V-Keyboard</h2>
    </div>
    <div class="modal-body">
        <div id="keyboard"></div>
        <div>
        </div>
    </div>
  </div>
</div>
<script>
    // Get the modal
var modal = document.getElementById('myModal');
$('input[type=text]').click(function () {
    $('#keyboard').unbind().removeData();
        $('#keyboard').jkeyboard({
            layout: "english",
            input: $('#'+$(this).attr('id'))
$('input[type=number]').click(function () {
            layout: "numbers_only",
var inputTags;
var inputType;
var getinputs = function() {
    inputTags = document.getElementsByTagName("input");
    console.log(inputTags)
    for (var i = 0; i < inputTags.length; i++) {
        inputTags[i].addEventListener('click', openModal, false)
setTimeout(function(){ getinputs(); }, 1000);
var inputTarget;
var openModal = function() {
    inputType = event.target.type
    inputTarget = event.target
    var layoutName;
    if (inputType == "number"){
        //inputTarget.type = "number" //hack because chrome doesn't allow setselection in number inputs
        //inputTarget.value = ""
        layoutName = "numbers_only"
    }else{
        layoutName = "english"
    $('#vkeyname').text(event.target.value)
    modal.style.display = "block";
        layout: layoutName,
// Get the <span> element that closes the modal
var span = document.getElementsByClassName("close")[0];
// When the user clicks on <span> (x), close the modal
//span.onclick = function(event) {
  //closeModal()
// When the user clicks anywhere outside of the modal, close it
window.onclick = function(event) {
    var source = event.target;
    if (source == modal || source == span) {
        closeModal(source)
var closeModal = function(source){
    //console.log("closing")
    modal.style.display = "none";
        inputTarget.type = "number" //hack because chrome doesn't allow selectionstart on number inputs
</script>
<script>
var clickState = 1;
var btn = document.querySelector('.VK');
btn.addEventListener('click', function(){
  if (clickState == 0) {
    this.textContent = 'V-KeyBoard On';
    clickState = 1;
  } else {
    this.textContent = 'V-KeyBoard Off';
    modal = document.getElementById('empty');
    clickState = 0;
</script>
<style>
.VK{
    position: fixed;
    top: 60px;
    right: 20px;
    height: 30px;
</style>
<div id="empty"></div>
<button class="VK">V-KeyBoard On</button>```
The class .modal-content has width property set to fit-content. Change it to max-content and see if it does the trick.
