Hi.
After installing
npm i node-red-node-serialport
my node-red worked once with serial communication also working.
Then after a reboot, it spits the following !
$ node-red
30 May 19:02:28 - [info]
Welcome to Node-RED
30 May 19:02:28 - [info] Node-RED version: v0.17.5
30 May 19:02:28 - [info] Node.js version: v8.11.0
30 May 19:02:28 - [info] Linux 4.16.12-200.fc27.x86_64 x64 LE
30 May 19:02:28 - [info] Loading palette nodes
30 May 19:02:29 - [warn] ------------------------------------------------------
30 May 19:02:29 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
30 May 19:02:29 - [info] Settings file : /home/harold/.node-red/settings.js
30 May 19:02:29 - [info] User directory : /home/harold/.node-red
30 May 19:02:29 - [info] Flows file : /home/harold/.node-red/flows_harold.json
30 May 19:02:29 - [info] Server now running at http://127.0.0.1:1880/
30 May 19:02:29 - [info] Waiting for missing types to be registered:
30 May 19:02:29 - [info] - ui_base
30 May 19:02:29 - [info] - ui_tab
30 May 19:02:29 - [info] - ui_group
30 May 19:02:29 - [info] - ui_link
30 May 19:02:29 - [info] - ui_slider
30 May 19:02:29 - [info] - ui_numeric
I had some problem during the installing and I’ve been asked to run a command as root, witch I have done but got an error.
But as I mentioned, it worked once !
