Node status not working what an i missing
i am creating a custom node that talks to a api i want to add some status to see what is happening but it wont work any help please
module.exports = function(RED) {
    function CabinetAction(config) {
        RED.nodes.createNode(this,config);
        var node = this;
        node.id = undefined;
        this.area = RED.nodes.getNode(config.area);
        this.ip = "";
        this.poort = 0;
        this.line1 = "";
        this.line2 = "";
        this.line3 = "";
        this.line4 = "";
        this.line5 = "";
        this.line6 = "";
        this.line7 = "";
        this.line8 = "";
        this.line9 = "";
        this.entry = "";
        this.badge = false;
        this.question = "";
        this.questionLenght = 0;
        this.digits = 0;
        this.decimals = 0;
        this.choices = "";
        this.out1 = 0;
        this.out2 = 0;
        this.out3 = 0;
        this.out4 = 0;
        this.out5 = 0;
        this.out6 = 0;
        this.out7 = 0;
        this.out8 = 0;
        this.out9 = 0;
        this.out10 = 0;
        this.out11 = 0;
        this.out12 = 0;
        this.out13 = 0;
        this.out14 = 0;
        this.out15 = 0;
        this.out16 = 0;
        this.clear = "No";
        this.weight = "No";
        node.on('input', function(msg, nodeSend, nodeDone) {
            //start check message
            thisabort = RED.util.evaluateNodeProperty('Abort', 'msg', this, msg);
            thiscallback = RED.util.evaluateNodeProperty('CallBack', 'msg', this, msg);
            if (thiscallback != undefined && thiscallback != null)
                if (node.area.areaid == thiscallback.AreaId){
                    if (node.id != undefined){
                        if (node.id == thiscallback._msgid){
                            msg.payload = new Object;
                            msg.payload.Value = thiscallback.Value;
                            msg.payload.Type = thiscallback.Type;
                            delete msg.CallBack;
                            node.status({fill:"green",shape:"dot",text:"{ Value: '"+thiscallback.Value+"', Type: '"+thiscallback.Type+"' }"});
                            nodeSend(msg);
                            nodeDone();
            else if (thisabort != undefined && thisabort != null && thisabort)
            else
                node.id = RED.util.evaluateNodeProperty('_msgid', 'msg', this, msg);
                prepare(msg,node,config,RED);
                node.status({fill:"yellow",shape:"dot",text:"Waiting for message"});
                nodeDone();
            //end check message
    RED.nodes.registerType("Cabinet Action",CabinetAction);
function prepare(msg,node,config,RED){
    node.ip = config.ip;
    if (config.ipType === 'msg' || config.ipType === 'flow' || config.ipType === 'global') {
        node.ip = RED.util.evaluateNodeProperty(config.ip, config.ipType, this, msg);
    node.poort = config.poort;
    if (config.poortType === 'msg' || config.poortType === 'flow' || config.poortType === 'global') {
        node.poort = RED.util.evaluateNodeProperty(config.poort, config.poortType, this, msg);
    if (config.line1Type === 'msg' || config.line1Type === 'flow' || config.line1Type === 'global') {
        node.line1 = RED.util.evaluateNodeProperty(config.line1, config.line1Type, this, msg);
    }else{
        node.line1 = config.line1;
    if (config.line2Type === 'msg' || config.line2Type === 'flow' || config.line2Type === 'global') {
        node.line2 = RED.util.evaluateNodeProperty(config.line2, config.line2Type, this, msg);
    }else{
        node.line2 = config.line2;
    if (config.line3Type === 'msg' || config.line3Type === 'flow' || config.line3Type === 'global') {
        node.line3 = RED.util.evaluateNodeProperty(config.line3, config.line3Type, this, msg);
    }else{
        node.line3 = config.line3;
    if (config.line4Type === 'msg' || config.line4Type === 'flow' || config.line4Type === 'global') {
        node.line4 = RED.util.evaluateNodeProperty(config.line4, config.line4Type, this, msg);
    }else{
        node.line4 = config.line4;
    if (config.line5Type === 'msg' || config.line5Type === 'flow' || config.line5Type === 'global') {
        node.line5 = RED.util.evaluateNodeProperty(config.line5, config.line5Type, this, msg);
    }else{
        node.line5 = config.line5;
    if (config.line6Type === 'msg' || config.line6Type === 'flow' || config.line6Type === 'global') {
        node.line6 = RED.util.evaluateNodeProperty(config.line6, config.line6Type, this, msg);
    }else{
        node.line6 = config.line6;
    if (config.line7Type === 'msg' || config.line7Type === 'flow' || config.line7Type === 'global') {
        node.line7 = RED.util.evaluateNodeProperty(config.line7, config.line7Type, this, msg);
    }else{
        node.line7 = config.line7;
    if (config.line8Type === 'msg' || config.line8Type === 'flow' || config.line8Type === 'global') {
        node.line8 = RED.util.evaluateNodeProperty(config.line8, config.line8Type, this, msg);
    }else{
        node.line8 = config.line8;
    if (config.line9Type === 'msg' || config.line9Type === 'flow' || config.line9Type === 'global') {
        node.line9 = RED.util.evaluateNodeProperty(config.line9, config.line9Type, this, msg);
    }else{
        node.line9 = config.line9;
    // msg.Line1 = node.line1;
    // msg.Line2 = node.line2;
    // msg.Line3 = node.line3;
    // msg.Line4 = node.line4;
    // msg.Line5 = node.line5;
    // msg.Line6 = node.line6;
    // msg.Line7 = node.line7;
    // msg.Line8 = node.line8;
    // msg.Line9 = node.line9;
    thisentry = RED.util.evaluateNodeProperty('Entry', 'msg', this, msg);
    if (thisentry != undefined && thisentry != null)
        node.entry = thisentry
    else{
        node.entry = config.input
    thisbadge = RED.util.evaluateNodeProperty('Badge', 'msg', this, msg);
    if (thisbadge != undefined && thisbadge != null)
        node.badge = thisbadge
    else{
        node.badge = config.badge
    //msg.Entry = node.entry;
    if (node.entry == 'AlphaNumeric')
        if (config.alphaNumericQuestionType === 'msg' || config.alphaNumericQuestionType === 'flow' || config.alphaNumericQuestionType === 'global') {
            node.question = RED.util.evaluateNodeProperty(config.alphaNumericQuestion, config.alphaNumericQuestionType, this, msg);
        }else{
            node.question = config.alphaNumericQuestion;
        if (config.alphaNumericLenght === 'msg' || config.alphaNumericLenght === 'flow' || config.alphaNumericLenght === 'global') {
            node.question = RED.util.evaluateNodeProperty(config.alphaNumericLenght, config.alphaNumericLenghtType, this, msg);
        }else{
            node.questionLenght = config.alphaNumericLenght;
        //msg.Question = node.question;
        //msg.QuestionLenght = node.questionLenght;
    if (node.entry == 'Numeric')
        if (config.numericQuestionType === 'msg' || config.numericQuestionType === 'flow' || config.numericQuestionType === 'global') {
            node.question = RED.util.evaluateNodeProperty(config.numericQuestion, config.numericQuestionType, this, msg);
        }else{
            node.question = config.numericQuestion;
        if (config.numericDigitsType === 'msg' || config.numericDigitsType === 'flow' || config.numericDigitsType === 'global') {
            node.digits = RED.util.evaluateNodeProperty(config.numericDigits, config.numericDigitsType, this, msg);
        }else{
            node.digits = config.numericDigits;
        if (config.numericDecimalsType === 'msg' || config.numericDecimalsType === 'flow' || config.numericDecimalsType === 'global') {
            node.decimals = RED.util.evaluateNodeProperty(config.numericDecimals, config.numericDecimalsType, this, msg);
        }else{
            node.decimals = config.numericDecimals;
        //msg.Digits = node.digits;
        //msg.Decimals = node.decimals;
    if (node.entry == 'Choice')
        if (config.choicesType === 'msg' || config.choicesType === 'flow' || config.choicesType === 'global') {
            node.choices = RED.util.evaluateNodeProperty(config.choices, config.choicesType, this, msg);
        }else{
            node.choices = config.choices;
        //msg.Choices = node.choices;
    thisout1 = RED.util.evaluateNodeProperty('Out1', 'msg', this, msg);
    if (thisout1 != undefined && thisout1 != null)
        node.out1 = thisout1
    else{
        node.out1 = config.out1
    thisout2 = RED.util.evaluateNodeProperty('Out2', 'msg', this, msg);
    if (thisout2 != undefined && thisout2 != null)
        node.out2 = thisout2
    else{
        node.out2 = config.out2
    thisout3 = RED.util.evaluateNodeProperty('Out3', 'msg', this, msg);
    if (thisout3 != undefined && thisout3 != null)
        node.out3 = thisout3
    else{
        node.out3 = config.out3
    thisout4 = RED.util.evaluateNodeProperty('Out4', 'msg', this, msg);
    if (thisout4 != undefined && thisout4 != null)
        node.out4 = thisout4
    else{
        node.out4 = config.out4
    thisout5 = RED.util.evaluateNodeProperty('Out5', 'msg', this, msg);
    if (thisout5 != undefined && thisout5 != null)
        node.out5 = thisout5
    else{
        node.out5 = config.out5
    thisout6 = RED.util.evaluateNodeProperty('Out6', 'msg', this, msg);
    if (thisout6 != undefined && thisout6 != null)
        node.out6 = thisout6
    else{
        node.out6 = config.out6
    thisout7 = RED.util.evaluateNodeProperty('Out7', 'msg', this, msg);
    if (thisout7 != undefined && thisout7 != null)
        node.out7 = thisout7
    else{
        node.out7 = config.out7
    thisout8 = RED.util.evaluateNodeProperty('Out8', 'msg', this, msg);
    if (thisout8 != undefined && thisout8 != null)
        node.out8 = thisout8
    else{
        node.out8 = config.out8
    thisout9 = RED.util.evaluateNodeProperty('Out9', 'msg', this, msg);
    if (thisout9 != undefined && thisout9 != null)
        node.out9 = thisout9
    else{
        node.out9 = config.out9
    thisout10 = RED.util.evaluateNodeProperty('Out10', 'msg', this, msg);
    if (thisout10 != undefined && thisout10 != null)
        node.out10 = thisout10
    else{
        node.out10 = config.out10
    thisout11 = RED.util.evaluateNodeProperty('Out11', 'msg', this, msg);
    if (thisout11 != undefined && thisout11 != null)
        node.out11 = thisout11
    else{
        node.out11 = config.out11
    thisout12 = RED.util.evaluateNodeProperty('Out12', 'msg', this, msg);
    if (thisout12 != undefined && thisout12 != null)
        node.out12 = thisout12
    else{
        node.out12 = config.out12
    thisout13 = RED.util.evaluateNodeProperty('Out13', 'msg', this, msg);
    if (thisout13 != undefined && thisout13 != null)
        node.out13 = thisout13
    else{
        node.out13 = config.out13
    thisout14 = RED.util.evaluateNodeProperty('Out14', 'msg', this, msg);
    if (thisout14 != undefined && thisout14 != null)
        node.out14 = thisout14
    else{
        node.out14 = config.out14
    thisout15 = RED.util.evaluateNodeProperty('Out15', 'msg', this, msg);
    if (thisout15 != undefined && thisout15 != null)
        node.out15 = thisout15
    else{
        node.out15 = config.out15
    thisout16 = RED.util.evaluateNodeProperty('Out16', 'msg', this, msg);
    if (thisout16 != undefined && thisout16 != null)
        node.out16 = thisout16
    else{
        node.out16 = config.out16
    thisclear = RED.util.evaluateNodeProperty('Clear', 'msg', this, msg);
    if (thisclear != undefined && thisclear != null)
        node.clear = thisclear
    else{
        node.clear = config.clear
    thisweight = RED.util.evaluateNodeProperty('Weight', 'msg', this, msg);
    if (thisweight != undefined && thisweight != null)
        node.weight = thisweight
    else{
        node.weight = config.weight
    if (node.ip !== "") {
        fetch("http://"+node.ip+":"+node.poort+"/FlowDevice/SetCabinet", {
            method: "PUT",
            headers: {
                "Content-Type": "application/json"
            body: JSON.stringify({
                "AreaId":node.area.areaid,
                "_msgid":msg._msgid,
                "Badge":node.badge,
                "Choices":node.choices,
                "Clear":node.clear,
                "Decimals":node.decimals,
                "Digits":node.digits,
                "Entry":node.entry,
                "Line1":node.line1,
                "Line2":node.line2,
                "Line3":node.line3,
                "Line4":node.line4,
                "Line5":node.line5,
                "Line6":node.line6,
                "Line7":node.line7,
                "Line8":node.line8,
                "Line9":node.line9,
                "Out1":node.out1,
                "Out10":node.out10,
                "Out11":node.out11,
                "Out12":node.out12,
                "Out13":node.out13,
                "Out14":node.out14,
                "Out15":node.out15,
                "Out16":node.out16,
                "Out2":node.out2,
                "Out3":node.out3,
                "Out4":node.out4,
                "Out5":node.out5,
                "Out6":node.out6,
                "Out7":node.out7,
                "Out8":node.out8,
                "Out9":node.out9,
                "Question":node.question,
                "QuestionLenght":node.questionLenght,
                "Weight":node.weight
        .then(response => {
            if (!response.ok) {
                msg.succes = false;
                msg.payload = response.statusText;
            return response.json();
        .then(data => {
            msg.payload.status = data;
            if (data)
                msg.succes = true;
                msg.payload.statusText = "Action accepted";
            else{
                msg.succes = false;
                msg.payload.statusText = "Action not accepted";
        .catch(error => {
            msg.succes = false;
            msg.payload = error;
At a super quick glance, possibly this:
Why are you clearing a nodes id? The id is an integral part of messages and routing in Node-RED.
