Anyone know of an existing node that could take multiple captured binary strings representing JPEG image data and combine them into an animated GIF with a specified frame rate? The use case is on doorbell ring, capture 5 or so images from the camera snapshot endpoint, and combine them into a GIF that can sent to phones. Capturing a single image is hit or miss to actually capture faces, etc.
Otherwise I might just write one, but thought I'd check first... I don't see anything like it in the flows library, but maybe Im not searching for the right term.
