Hello Everyone, I am new to NodeRed. I want to set properties of the marked nodes V1 and V2 both of which are custom from an iframe embedded in the ui dashboard. Is something like this possible ? More distinctly,
- Is it possible to open the ui-dashboard page upon clicking some property inside the node v1 or v2?
- Is it possible to grab certain things (generally strings) from the embedded iframe and set it in another node property of the same node, i.e. V1 or V2?
- Is there a way to lock the UI-Dashboard? (as in no changes allowed after initial configuration which i need to read about more
Any help would be much appreciated.
Thanks in advance.
Edit: I am aware of how to establish communication between the iframe and the dashboard site and circumventing CORS via window.postMessage(), and also how to add iframes via the ui-template node / a link.
