Node --trace-warnings
At start my raspberry Pi4 I have this error:
(node:1548) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 flows:started listeners added to [EventEmitter]. Use emitter.setMaxListeners() to increase limit
(Use node --trace-warnings ... to show where the warning was created)
Well, I don't understand how to use
`node --trace-warnings ...`
like this?
node-red node --trace-warnings
or how?
Thank you ...
No, the correct syntax is something like this:
node --trace-warnings node_modules/node-red/red.js
Though you obviously need to provide the correct path to the red.js file.
Ok, thank you ....
I start node red through docker. How to use node --trace warnings
Thank you !
No idea, sorry. I don't use Docker for Node-RED.
