Nodered and mqtt : parsing a message
I am new to using nodered.
I'm having quite a bit of difficulty in transforming and processing mqtt messages.
The goal is to transform a mqtt message and update the HA UI.
I created all the data as input_text, the data has the same name in the MQTT message.
I'm sending from an mqtt client messages that look like this.
/Test/demo/test : msg.payload : string[634]
"{"infos_chaudiere_temp_sonde" : "10",
  "infos_chaudiere_temp_ext" : "10",
  "infos_chaudiere_temp_salon" : "10",
  "infos_chaudiere_consommation_jour_chauffage" : "10",
  "infos_chaudiere_consommation_jour_eau_chaude" : "10",
  "infos_chaudiere_consigne_temperature_confort " : "10",
  "infos_chaudiere_consigne_temperature_reduit " : "10",
  "infos_chaudiere_consigne_temperature_party " : "10",
  "infos_chaudiere_consigne_temperature_eau_chaude" : "10",
  "infos_chaudiere_temp_corps" : "10",
  "infos_chaudiere_temp_ecs" : "10",
  "infos_chaudiere_temp_fumées" : "10",
  "infos_chaudiere_puissance" : "10",
  "infos_chaudiere_temps_fonctionnement" : "10"}"
After the message arrives, I get this ( as you can see the decoded value is an empty string, why ?)!
  27/03/2022, 12:48:47node: 99e3ae88da717887
  msg :
  object
  domain: "input_text"
  service: "set_value"
  data: object
  value: ""
  entity_id: "input_text.infos_chaudiere_temp_sonde"
  27/03/2022, 12:48:47node: 97dda74252a5ac22
  /Test/demo/test : msg : Object
  object
  topic: "/Test/demo/test"
  payload: object
  data: object
  value: ""
  qos: 2
  retain: false
  _topic: "/Test/demo/test"
_msgid: "f5598f08dfbb326e"
Here is the nodered :
        "id": "d76fc4e57706f6fe",
        "type": "tab",
        "label": "MQTT",
        "disabled": false,
        "info": "",
        "env": []
        "id": "69880985f1586235",
        "type": "comment",
        "z": "d76fc4e57706f6fe",
        "name": "Chaudière",
        "info": "",
        "x": 80,
        "y": 60,
        "id": "e264a5db96aa8980",
        "type": "mqtt in",
        "name": "infos_chaudière",
        "topic": "/Test/demo/test",
        "qos": "2",
        "datatype": "auto",
        "broker": "6ce377512fcb384f",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 120,
        "y": 120,
                "d5185a7193d60f33",
                "99e3ae88da717887"
        "id": "99e3ae88da717887",
        "type": "api-call-service",
        "server": "11a90641.be375a",
        "version": 5,
        "debugenabled": true,
        "domain": "input_text",
        "service": "set_value",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "{ \"value\"  : \"{{payload.infos_chaudiere_temp_sonde}}\"}",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "data"
        "queue": "none",
        "x": 380,
        "y": 100,
                "97dda74252a5ac22"
        "id": "97dda74252a5ac22",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 590,
        "y": 100,
        "id": "d5185a7193d60f33",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 350,
        "y": 160,
        "id": "6ce377512fcb384f",
        "type": "mqtt-broker",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "id": "11a90641.be375a",
        "type": "server",
        "name": "Home Assistant",
        "version": 2,
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": false,
        "cacheJson": false,
        "heartbeat": false,
        "heartbeatInterval": 30
Thanks for your help.
Bernard
Welcome to the forum!
Try removing the leading and trailing quotation marks from your string:
	"infos_chaudiere_temp_sonde": "10",
	"infos_chaudiere_temp_ext": "10",
	"infos_chaudiere_temp_salon": "10",
	"infos_chaudiere_consommation_jour_chauffage": "10",
	"infos_chaudiere_consommation_jour_eau_chaude": "10",
	"infos_chaudiere_consigne_temperature_confort ": "10",
	"infos_chaudiere_consigne_temperature_reduit ": "10",
	"infos_chaudiere_consigne_temperature_party ": "10",
	"infos_chaudiere_consigne_temperature_eau_chaude": "10",
	"infos_chaudiere_temp_corps": "10",
	"infos_chaudiere_temp_ecs": "10",
	"infos_chaudiere_temp_fumées": "10",
	"infos_chaudiere_puissance": "10",
	"infos_chaudiere_temps_fonctionnement": "10"
[quote="Bercolly, post:1, topic:60401"]
I don't know about the Home Assistant node but if you change your MQTT-in node to output "A parsed JSON object" the payload will be easier to process in Node-red.
Actually I think @ghayne just said basically the same thing.
