Hello there,
I need to establish an interface in OPENHAB2 for humidity and temperature data logger.
I would like to work with NodeRed Dash Board for an easier method.
I wonder if we can install NodeRed Dash Board withOpenhab2.
Since we have found in a site web that NodeRed DAsh Board requires Raspbian.
I am looking forward to hearing from you as soon as possible because we are beginners in this area and we do need the project.
Thanks in advance.
Node-RED can be installed on many different platforms - macOS, Windows and Linux are just some. The dashboard is part of Node-RED - you use NR to build the dashboard so you would have to send data from OPENHAB2 to NR (there even a node: node-red-contrib-openhab2)
Since you are a beginner, you should take small steps before you try to run.
- read the documentation https://nodered.org/docs/user-guide/
- try the
first flowexample https://nodered.org/docs/getting-started/first-flow - try some of the flows in the cookbook https://cookbook.nodered.org
Only then start playing with the connection to OpenHab2 and it will mke your life easier.
