Nodered Modbus TCP Maico KWL
I would read and write my Maico KWL. The "Lüftungsanlage" is created and connected.
I would write "Stoßlüftung " to on but it did not work. The payload 1 send but nothing do.
[{"id":"c8bb1d688921ebde","type":"tab","label":"Flow 6","disabled":false,"info":"","env":[]},{"id":"b0f9055fda3e114e","type":"modbus-write","z":"c8bb1d688921ebde","name":"Stoßlüften","showStatusActivities":false,"showErrors":false,"unitid":"1","dataType":"MHoldingRegisters","adr":"551","quantity":"1","server":"94c8f3345386013a","emptyMsgOnFail":false,"keepMsgProperties":false,"x":710,"y":160,"wires":[[],[]]},{"id":"74a417e9d35449d2","type":"function","z":"c8bb1d688921ebde","name":"aktiv","func":"return {payload: '1'};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":160,"wires":[["b0f9055fda3e114e"]]},{"id":"d514107501930212","type":"function","z":"c8bb1d688921ebde","name":"deaktivieren","func":"return {payload: '0'};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":100,"wires":[["b0f9055fda3e114e"]]},{"id":"949d072893028b8b","type":"inject","z":"c8bb1d688921ebde","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":100,"wires":[["d514107501930212"]]},{"id":"4e022121c8bd9bcb","type":"inject","z":"c8bb1d688921ebde","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":160,"wires":[["74a417e9d35449d2"]]},{"id":"94c8f3345386013a","type":"modbus-client","name":"Lüftungsanlage","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.31.171","tcpPort":"502","tcpType":"TELNET","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
551		Stoßlüftung	03-Read Holding Register(4x)	06-Write Single Register	16-Write Multiple Register	1	uint16	0	1	0	1		0=inaktiv; 1=aktiv
