Nodered to sqlite to grafana help
Hello again,
Does anybody use the sqlite+grafana combo? (influxdb is too complicated for me).
My time series column is TEXT datatype with “YYYY-MM-DDTHH:MM:SS” (tried different formats, without the "T" too).
Yet when I set "datetimestamp" to be recognized as a time series column, the values disappear.
When I leave it like that, i can see the values in the query table but no chart is drawn in both cases.
I know it's not the most node-red-ish issue, help please.
I was doing the same thing with node-red > csv > smb > grafana (different linux pc) and it worked flawlessly. I assume I don't have the right knowledge about the perfect sql query syntax for my case.
As timeseries;
No timeseries;
Thank you kindly for any advice.
I don't have any experience with sqlite in combination with grafana so no ready to run solution from me :wink:
Have a look at this SQLite plugin for Grafana | Grafana Labs and then in particular the paragraph about Support for Time Formatted Columns
With the provided example you should get it working.
Cheers mate, the "Z" was missing from the format's end.
