Though probably you just need to change now to now.getTime()
The latest linter in node-red doesn't know about subtracting Date objects. The code will work as it is because the interpreter will call getTime() automatically.
I used your code from above (great btw) without any changes.
// determines the average of all payload values passed in
// over the specified time range
const range = 20 * 60 * 1000; // window time millisecs
let buffer = context.get('buffer') || [];
let total = context.get('total') || 0; // the accumulated total so far
let now = new Date();
let value = Number(msg.payload);
// remove any samples that are too old
while (buffer[0] && buffer[0].timestamp < now - range) {
// remove oldest sample from array and total
node.warn(`removing oldest ${buffer[0].timestamp}`);
total -= buffer[0].value;
buffer.shift();
// add the new sample to the end
buffer.push({timestamp: now, value: value});
total += value;
context.set('buffer', buffer);
context.set('total', total);
msg.payload = total/buffer.length;
node.warn(`length: ${buffer.length}, total: ${total}, average: ${msg.payload}`);
