I'd like to set dynamically the labels of the OK and the Cancel buttons of a dashboard "show dialog" node (i.e. a notification node with OK/Cancel layout). I need that as I'm doing a multilingual dashboard, and I need to translate at least the word "Cancel" ![]()
I've tried using {{msg.ok}} and {{msg.cancel}} in the according fields in the node configuration (see screen capture below), but they don't seem to be evaluated (I get "{{msg.ok}}" or "{{msg.cancel}}" in the output payload)...
I also didn't see in the node help any information about a msg property to be used for this.
Is there any way to do it?
Thanks folks !
