Nice i wanted to install
node-red-contrib-ui-svg
A Node-RED widget node to show interactive SVG (vector graphics) in the dashboard
But it got the error see below.
I run node red on a raspberry. I thin it has a fixed IP...
Before some time it worked.
But now the npm makes trouble ![]()
2020-10-05T19:57:17.272Z installieren : node-red-contrib-ui-svg 2.0.3
2020-10-05T19:57:29.429Z npm install --no-audit --no-update-notifier --save --save-prefix="~" --production node-red-contrib-ui-svg@2.0.3
2020-10-05T19:57:45.460Z [err] npm
2020-10-05T19:57:45.462Z [err]
2020-10-05T19:57:45.462Z [err] ERR! code ENETUNREACH
2020-10-05T19:57:45.464Z [err] npm
2020-10-05T19:57:45.465Z [err] ERR!
2020-10-05T19:57:45.465Z [err] errno ENETUNREACH
2020-10-05T19:57:45.494Z [err] npm
2020-10-05T19:57:45.495Z [err] ERR!
2020-10-05T19:57:45.495Z [err] request to https://registry.npmjs.org/node-red-contrib-ui-svg failed, reason: connect ENETUNREACH 104.16.20.35:443 - Local (0.0.0.0:0)
2020-10-05T19:57:45.529Z [err]
2020-10-05T19:57:45.530Z [err] npm ERR!
2020-10-05T19:57:45.530Z [err] A complete log of this run can be found in:
2020-10-05T19:57:45.530Z [err] /home/pi/.npm/_logs/2020-10-05T19_57_45_502Z-debug.log
2020-10-05T19:57:45.566Z rc=
Here is the npm config?
npm config list --json
"json": true,
"user-agent": "npm/6.14.8 node/v10.15.2 linux arm",
"metrics-registry": "https://registry.npmjs.org/",
"scope": "",
"access": null,
"allow-same-version": false,
"always-auth": false,
"also": null,
"audit": true,
"audit-level": "low",
"auth-type": "legacy",
"before": null,
"bin-links": true,
"browser": null,
"ca": null,
"cache": "/home/pi/.npm",
"cache-lock-stale": 60000,
"cache-lock-retries": 10,
"cache-lock-wait": 10000,
"cache-max": null,
"cache-min": 10,
"cert": null,
"cidr": null,
"color": true,
"depth": null,
"description": true,
"dev": false,
"dry-run": false,
"editor": "vi",
"engine-strict": false,
"force": false,
"format-package-lock": true,
"fund": true,
"fetch-retries": 2,
"fetch-retry-factor": 10,
"fetch-retry-mintimeout": 10000,
"fetch-retry-maxtimeout": 60000,
"git": "git",
"git-tag-version": true,
"commit-hooks": true,
"global": false,
"globalconfig": "/usr/etc/npmrc",
"global-style": false,
"group": 1000,
"ham-it-up": false,
"heading": "npm",
"if-present": false,
"ignore-prepublish": false,
"ignore-scripts": false,
"init-module": "/home/pi/.npm-init.js",
"init-author-name": "",
"init-author-email": "",
"init-author-url": "",
"init-version": "1.0.0",
"init-license": "ISC",
"key": null,
"legacy-bundling": false,
"link": false,
"loglevel": "notice",
"logs-max": 10,
"long": false,
"maxsockets": 50,
"message": "%s",
"node-options": null,
"node-version": "10.15.2",
"offline": false,
"onload-script": null,
"only": null,
"optional": true,
"otp": null,
"package-lock": true,
"package-lock-only": false,
"parseable": false,
"prefer-offline": false,
"prefer-online": false,
"prefix": "/usr",
"preid": "",
"production": false,
"progress": true,
"proxy": null,
"https-proxy": null,
"noproxy": null,
"read-only": false,
"rebuild-bundle": true,
"registry": "https://registry.npmjs.org/",
"rollback": true,
"save": true,
"save-bundle": false,
"save-dev": false,
"save-exact": false,
"save-optional": false,
"save-prefix": "^",
"save-prod": false,
"script-shell": null,
"scripts-prepend-node-path": "warn-only",
"searchopts": "",
"searchexclude": null,
"searchlimit": 20,
"searchstaleness": 900,
"send-metrics": false,
"shell": "/bin/bash",
"shrinkwrap": true,
"sign-git-commit": false,
"sign-git-tag": false,
"sso-poll-frequency": 500,
"sso-type": "oauth",
"strict-ssl": true,
"tag": "latest",
"tag-version-prefix": "v",
"timing": false,
"tmp": "/tmp",
"unicode": true,
"unsafe-perm": true,
"update-notifier": true,
"usage": false,
"user": 0,
"userconfig": "/home/pi/.npmrc",
"umask": 18,
"version": false,
"versions": false,
"viewer": "man",
"globalignorefile": "/usr/etc/npmignore"
Has someone any idea?
Thank you ![]()
