When running nr-lint it seem to fail and does not emit any warnings/errors anymore.
`$ npx nrlint flows.json` `Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './conf/environments' is not defined by "exports" in /builds/platynum/certification-authority/flows/node_modules/@eslint/eslintrc/package.json` ` at new NodeError (node:internal/errors:371:5)` ` at throwExportsNotFound (node:internal/modules/esm/resolve:453:9)` ` at packageExportsResolve (node:internal/modules/esm/resolve:731:3)` ` at resolveExports (node:internal/modules/cjs/loader:482:36)` ` at Function.Module._findPath (node:internal/modules/cjs/loader:522:31)` ` at Function.Module._resolveFilename (node:internal/modules/cjs/loader:919:27)` ` at Function.Module._load (node:internal/modules/cjs/loader:778:27)` ` at Module.require (node:internal/modules/cjs/loader:1005:19)` ` at require (node:internal/modules/cjs/helpers:102:18)` ` at Object.<anonymous> (/builds/platynum/certification-authority/flows/node_modules/eslint4b/dist/index-1a487e30.js:13:20) {` ` code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'` `}` `╔═══════════╤══════════╤═════════╤══════╗` `║ Object ID │ Severity │ Message │ Rule ║` `╚═══════════╧══════════╧═════════╧══════╝` `✖ 0 problems (0 errors, 0 warnings)`
But the command does not fail, the exit code is 0. What has to be installed to get this command running again? Is it possible to detect this or similar errors in a shell script?
