What confusion?
It's simple.
A constant is a constant unless it is an object at which point it is mostly constant but not quite.
What confusion?
It's simple.
The reason is that objects and arrays are accessed by reference. So when I say
let a = {x:1, y:2}
a is effectively a pointer to the object (or array), not the actual object. The reason javascript works like this is for efficiency, as if I now say
let b = a
then it is not necessary to make a copy of the object and put it into b (which would be onerous for large arrays or objects), but just point b to the object. So if I say
const obj = {x:1, y:2}
I am saying that obj is a constant pointer to an object, meaning that the pointer cannot change. Not that obj is a pointer to a constant object.
Personally I usually don't use const for objects and arrays as it is easily misunderstood.
Thank you for that Colin,
I can now see how it all comes together, it requires me to have a slight shift in my mind set. I wrote a lot of my stuff using this...
LDA 30H
MOV B.A
LXI H.41H
LXI D.61H
ANA A
ADDW: LDAX D
ADC M
MOV M.A
INX D
INX H
DCR B
JNZ ADDW
JMP XXXXH
8080 ASM
I will keep your explanation as an aide memoire. I get it, just need to remember it!![]()
We are obviously of the same vintage.
I learned and wrote 6502 Assembly and even learned to read but not write some IBM 370 mainframe assembly. But I always preferred FORTH. ![]()
I loved the idea for FORTH but when I tried to use it for anything serious it didn't really work well for me.
It is certainly a VERY different way of thinking. It took me a while to get my head around it certainly. However, its ability to write code in a high-level language and yet compile down to something utterly tiny was a real draw back in the day where memory might be maxing out at a few kB rather than the GB we have today.
The famous example was that of an airport operations tool that was completely written in FORTH and ran on a very small computer.
I was using it on the BBC Micro and it was great there.
Had the BBC Micro and used it to develop some Hardware that a couple of us had developed. We then went on to writing the code for the 8080 which had a max (iirc) of 64kB of addressable EPROM for the program and the RAM was much less. CPU cycles and Memory usage were both critical things for us!
The closest I got to FORTH was the Opto22 PAC Controllers, they evidently ran on a version of Forth, but I didn't really interface with that directly.
Of course, things got very 'professional' when I add the CP/M Module with the Business Package Software and two 5 1/4" Disk Drives. :lol
Of the fun of it all.
Oooh, this looks fun. https://www.npmjs.com/package/webforth
I think we absolutely need to be able to code in FORTH within node-red. I am surprised that no-one has provided this already. Forget typescript, lets GO FORTH.
I look forward to seeing your function-forth node! ![]()
