NR_NODE_NAME in 2.2.0 does not appear to be set
Guys,
thanks I am loving the new capability in 2.2.0 (we are currently pinned to 2.1.3 for our prod instances and need to upgrade) to get the node and flow details from the env object
have a function
msg.nrNodeId = env.get("NR_NODE_ID");
msg.nrNodeName = env.get("NR_NODE_NAME");
msg.nrNodePath = env.get("NR_NODE_PATH");
msg.nrGroupId = env.get("NR_GROUP_ID");
msg.nrGroupName = env.get("NR_GROUP_NAME");
msg.nrFlowId = env.get("NR_FLOW_ID");
msg.nrFlowName = env.get("NR_FLOW_NAME");
msg.payload = `I was sent by Function ${msg.nrNodeName}, on Flow '${msg.nrFlowName}`
msg.env = env
it is returning
{"_msgid":"eb2947b81078e8f7","payload":"I was sent by Function , on Flow 'Flow 1","topic":"","nrNodeId":"ab7b26a8695984e6","nrNodeName":"","nrNodePath":"c6102b2d.d908e8/ab7b26a8695984e6","nrFlowId":"c6102b2d.d908e8","nrFlowName":"Flow 1","env":{}}
I don't appear to be getting the NR_NODE_NAME variable. Is this a bug or am I doing something silly?
Its working for me (running on the beta version of NR) ..
silly question .. do you have a name for your Function ? :face_with_monocle:
you can also try msg.nrNodeName = node.name
it should give you the same thing
No silly questions only embarrassed posters - That was exactly the problem - :man_facepalming:
