NTP Time Server Node
Dont delete it BUT put a very strong recommendation that people think about the greater good and do not spam the public NTP servers.
I have not looked at your node but presumably you can direct it to look at any NTP server - if so it would be worthwhile telling people to try and only use their own internal NTP servers if they are going to hit NTP sources heavily (but as Julian says i can not understand why you would either)
Craig
Most, and every public NTP server I've ever looked at limit requests from an IP address as well. So if you hit the server too often they will block your IP anyway. Don't recall what that time limit is but easy to find out.
Thank you for the hints.
I changed the default cycle time to 1 minute in the node.
I removed queries in ms.
I have also added a note to blocking the IP
for very short queries to the node description.
Looked up the time for server requests and they state NEVER request time more than every four seconds so I'd say a minute is comfortably outside that spec.
I want to chime in here, not everyone understand ever single use of these (2) nodes, I'm sure there are applications (just like mine) that has a need for such a node!
PLEASE DO NOT DELETE>
