I am Running node-red 1.3.0-beta.1 with node.js V 12.11.1 on Odroid C2 on Kernel 5.14.19 .
I installed npm install johnny-five
with no problems
then I installed
npm install odroid-io
with no problems either.
But as soon a node (in my case node-red-contrib-gio: gpio-in ) uses the "Odroid-io" plugin , node-red crashed with:
TypeError: Cannot read property 'index' of undefined
at OdroidIO.normalize (/home/odroid/node_modules/odroid-io/lib/odroid-io.js:182:32)
at OdroidIO.pinMode (/home/odroid/node_modules/odroid-io/lib/odroid-io.js:189:33)
at iopluginNode.<anonymous> (/home/odroid/.node-red/node_modules/node-red-contrib-gpio/gpio.js:82:20)
at iopluginNode.emit [as _emit] (events.js:210:5)
at iopluginNode.Node.emit (/home/odroid/.nvm/versions/node/v12.11.1/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:181:20)
at /home/odroid/.node-red/node_modules/node-red-contrib-gpio/lib/iopluginNode.js:38:16
at processTicksAndRejections (internal/process/task_queues.js:75:11)
at runNextTicks (internal/process/task_queues.js:62:3)
at processImmediate (internal/timers.js:412:9)
at process.topLevelDomainCallback (domain.js:131:23)
**1 Mar 04:27:06 - [red] Uncaught Exception:
1 Mar 04:27:06 - TypeError: Cannot read property 'index' of undefined**
at OdroidIO.digitalRead (/home/odroid/node_modules/odroid-io/lib/odroid-io.js:225:23)
at iopluginNode.<anonymous> (/home/odroid/.node-red/node_modules/node-red-contrib-gpio/gpio.js:83:14)
But how to update best from 1.3.0-beta.1 to 1.37 ( and finally to nodered v2.xxx), please?
I just upgraded from node.js 12.11.1 tp 17.1.0.
now odroid-io not crashing nodered anymore but get the following: ??
weird:
error loading plugin odroid-io The module '/home/odroid/node_modules/i2c-bus/build/Release/i2c.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 102. This version of Node.js requires
NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
Why did you jump to node.js v17.1.0? I would go to v16 at the current point in time
That error is saying that odroid-io was compiled with a different version of Node.js. You could try compiling it but I'd still be looking to the author of the odroid-io node for help.
After a major version upgrade of nodejs you must go into the .node-red folder and run npm rebuild
But as pointed out already, don't use V17, use an LTS version which is 16 (or 14 or 12).
I am on nodered 2.1.3 now and everything works stable, so far.
But then I install node-red-contrib-johnny5 (from palette) and the ioplugin:
odroid-io
with npm install odroid-io
which seems to be a prererequisite for the johnny5 - nodes.
Unfortunately there is neither for the johnny5 node nore @ hte odroid-io plug in ANY support at all:
Unfortunately due to my situation (odroid, Kernel 5) and the spec of the johnny5 node, there is no other alternative in terms of gpiod!
However, no matter which config I use - absolutely no luck.. I had the configs:
nvm 12.22.1
npm 6.14.15 (or 8.1.3)
nvm 14.18.1
npm 8.1.3
nvom 16.13.0
npm 8.1.3
no luck
I am kind of stuck having npm install or npm rebuild kicking out my node-red-contrib-johnny5 node as well as my odroid-io config node, du to several errors and incompatibilities!
please help.
I have huge project here where we switched from kernel 3.16.85 (gipio ion sysfs, wiringpi (Gordon's) all the way up to 5.13.14 (gpiod, but odroid --> no wiringpi support anymore, gpiod only for raspi) and now I need to get my GPIOs going again on node red!!
however its really sad. no gpiod supprt on ARM64 boards for node-red.
I searched a lot - but no way.
Since Kernel 4.8 and since Gordon killed his support the Odroid Users plummeted in a Node-red GPIO(D)-hole, which is really hard to escape.
Throughout the pinning mess over all the different platforms it's absolutly understandable on one side that the developers give up on maintain node-red modules like "odroid-io" for the johnny-five" community or
"what-ever-contrib-pi-gpiod"
developers conectrate on Raspi leaving odroid behind but on the other hand thats sad. Thats sad, really sad.
However gpiomon is NOT working on modern kernels yet on Ondroid at all becuse the interrupt() was not set for the pins, but thats a whole lot a different story ......
(help gpio irq mainline kernel - ODROID)
However if some one (probably @Kolleary@Colin ) has an idea how to overcome this please HELP!
I have had a couple of Odroids myself (XU4 and N2) that I used earlier. At the time they arrived they performed very well in comparison with previous versions of the RPi. I remember there was special also in the OS and special when you had to keep them updated. So today they are retired, the XU4 is since long recycled. For me this was not a problem to move on to other devices since it was only for personal usage. For you, if you have a large customer project, I understand the problems are much worse
Your C2 is listed as obsolete/discontinued. It is of course not good news for you and it could cause huge problems if you have a large project as you say and later will run out of spare parts/replacements. Time to think about migrating to a newer platform? Or consider another topologi for your I/O controls, using separate boards instead
