The title kind of speaks for itself.
But I was just wondering what the difference is.
A subflow is limited to 1 input.
I'm not exactly sure a node is.
Not that I have ever really seen any nodes with more than 1 input.
Other than with a subflow you can see the inner workings.......
And change them if you desire.
But in all honesty, I guess you can with a node too.
It is just a different method of doing it.
All nodes have that restriction.
A subflow is implemented by you in the Node-RED editor. Its inner workings are a flow of nodes.
A 'regular' node is implemented in JavaScript.
A subflow exists as a "thing" in your flow file. If you delete your flow file, you no longer have any subflows defined.
A node is installed into the runtime via npm. It will be available in the palette regardless of what flows file the runtime is told to use.
