OK.. this has got me stumped! MQTT Out Node Odd Error?
If I inject via 'Test' it works, if I inject via 'Volume 15' works. but if I click on 'Test' to populate the 'Tevevisions' table, then click on the 'Televisions' table row 1 (only row) which uses the same function node as 'Test', the MQTT OUT node fails with this very odd error.
Error... "Error: Invalid action specified"
{"payload":"address=192.168.1.24&media=84:90:0a:7f:1e:00&key=TUU715C8&topic=volume&message=15","action":"row_click","_client":{"socketId":"Yc4Veh3F7oB_-byJAAAH","socketIp":"192.168.1.34"},"_msgid":"174a37b1dc3c5a38","error":{"message":"Error: Invalid action specified","source":{"id":"f29975a35fd9e47a","type":"mqtt out","name":"Publish (command/television)","count":1},"stack":"Error: Invalid action specified\n    at MQTTOutNode._inputCallback (/usr/lib/node_modules/node-red/node_modules/@node-red/nodes/core/network/10-mqtt.js:1480:30)\n    at /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:214:26\n    at Object.trigger (/usr/lib/node_modules/node-red/node_modules/@node-red/util/lib/hooks.js:166:13)\n    at Node._emitInput (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:206:11)\n    at Node.emit (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:190:25)\n    at Node.receive (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:499:10)\n    at deliverMessageToDestination (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:817:40)\n    at Immediate._onImmediate (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:833:21)\n    at process.processImmediate (node:internal/timers:483:21)"},"_event":"node:51f4208a73304370"}
Flow...
[{"id":"a4cafcfc664d456d","type":"function","z":"278a09b3f0abe33b","name":"Function","func":"msg.payload = 'address=192.168.1.24&media=84:90:0a:7f:1e:00&key=TUU715C8&topic=volume&message=15'\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1180,"y":600,"wires":[["f29975a35fd9e47a"]]},{"id":"7964205f6031c73b","type":"inject","z":"278a09b3f0abe33b","name":"Volume 15","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"address=192.168.1.24&media=84:90:0a:7f:1e:00&key=TUU715C8&topic=volume&message=15","payloadType":"str","x":1180,"y":640,"wires":[["f29975a35fd9e47a"]]},{"id":"ecd24545baea07b2","type":"inject","z":"278a09b3f0abe33b","name":"Test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1030,"y":620,"wires":[["a4cafcfc664d456d"]]},{"id":"d007b939d174a9a8","type":"ui-table","z":"278a09b3f0abe33b","group":"75ea6668946ef1c1","name":"Televisions","label":"Televisions","order":2,"width":"","height":"","maxrows":0,"passthru":false,"autocols":true,"showSearch":false,"deselect":true,"selectionType":"click","columns":[],"mobileBreakpoint":"sm","mobileBreakpointType":"defaults","action":"replace","className":"","x":1010,"y":580,"wires":[["a4cafcfc664d456d"]]},{"id":"8c51dc93980bbb84","type":"inject","z":"278a09b3f0abe33b","name":"Test Table","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"payload[0].Device","v":"Test","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[]","payloadType":"jsonata","x":860,"y":580,"wires":[["d007b939d174a9a8"]]},{"id":"f29975a35fd9e47a","type":"mqtt out","z":"278a09b3f0abe33b","name":"Publish (command/television)","topic":"command/television","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"18041d7c9ea500d9","x":1400,"y":620,"wires":[]},{"id":"75ea6668946ef1c1","type":"ui-group","name":"Television Control","page":"a129af50497c821b","width":8,"height":1,"order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"18041d7c9ea500d9","type":"mqtt-broker","name":"Broker","broker":"broker.dachshund-digital.org","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"5","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"a129af50497c821b","type":"ui-page","name":"Dachshund Digital","ui":"b9d115efa0ea05a2","path":"/Casitas","icon":"home","layout":"grid","theme":"eae0f4a4353a3ec9","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":true,"disabled":false},{"id":"b9d115efa0ea05a2","type":"ui-base","name":"Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true,"allowInstall":false},{"id":"eae0f4a4353a3ec9","type":"ui-theme","name":"Dark","colors":{"surface":"#008080","primary":"#008080","bgPage":"#000000","groupBg":"#000000","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}},{"id":"cf70bd7b6ada1adc","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.29.0"}}]
Tried restarting NR thinking something nasty happened under the hood. But the issue is consistent and repeatable. There is nothing about the topic or the payload that is different between all the variants that I can see, the broker never gets the topic/message, this is all within the MQTT OUT node as far as I can see.
I can't look at the flows at the moment, but does the message you are sending in include msg.action? If so that is meaningful to the mqtt node. Check the node's help text.
Yes... I was walking the code in the /usr/lib/node_modules/node-red/node_modules/@node-red/nodes/core/network/10-mqtt.js file... and added a console.log line to expose msg.action... and that is set to 'row_click' which is not in the allowed actions list! I had not as yet looked to the help text. RTFM I guess LOL
By that I mean the text that appears in right hand pane when you select the node and click the book icon at the top
Yup... I should have checked the help... hence my R.T.F.M. comment. The fact that 'msg.action' is common across the applicable nodes in this case... I have, even using NR for years... tripped for this issue, until now.
