Hi all
I'm intereseting to start some functions when group is loaded or flow is loaded.
this is possible?
many thanks in advance
Sounds like you should look at the ui control node
What do you mean by loaded? Do you mean when the dashboard tab is opened in the browser? If so then as suggested you want the UI control node.
