Dear Sir,
I'm facing an UI issue only with mobile browser:
I have started the project with Nore-Red V2 and now I'm with V3 on raspberry with OS bullseye 32bit.
I'm working every day o the flow to add sensor and dashboard elements, so I don't know after what kind of change I started this issue:
With the computer browser all is always OK.
On the mobile android smartphone browser (chrome or Brave),with Samsung, Honor and Huawai smartphone, the UI dashboard is showed JUST the first time I enter..
If I refresh or close the browser and re-open the webpage, no gui is showed and I receiver a "connection error"
While on the mobile smartphone I have "error" in the same time, on the PC Notebook it WORKS!
**Is enought to delete che COOCKIE ** of the IP address page, that the UI is showed again, BUT after refresh, the error reappear.
I'm using HTTP and not HTTPS!
Is this issue common?
What can I check?
Thanks in advance.
Are the mobile devices connected to the wi-fi on the same network as node red? YES
What ip address are you using to access node red? http://192.168.55.11:1880/ui/ same IP 192.168.55.* af all my house, modem/router/PC, smartphone etc etc
After delete the cookie on the mobile browser (Chrome OR brave) the UI is showed.
I exit/close the browser.
If I enter again into the UI, it give connection error. (In the same time on the PC/Notebook, the UI is showed and works properly)
Then if I delete the cookie, then exit to browser, when I re-enter,the UI is showed.
If I exit and re-enter from browser UI IP another time, the UI is another time stuck.
There is some settings into the nodered that can block or generate this error (Stop the use of coockie or others solutions?)
But does it work correctly provided you stay on that screen? You have still not made that clear. You have said it shows the first time, but not confirmed that it fully works.
I mean that I have to enter into browser settings and delete the "cookies".
UPDATE: AFTER UPDATE the Node-Red UI "node-red-dashboard" to v. 3.2.0 the issue is disappeared!
Thanks for your support
