Benja
16 February 2021 19:04
1
Hi, i need help again
is there a way to leave these 3 function nodes in one?, they are all the same id, different registers.
msg.payload = { value: msg.payload,
'fc': 3,
'unitid': 3,
'address': 6003,
'quantity': 1 }
'fc': 3,
'unitid': 3,
'address': 200 ,
'quantity': 10 }
'fc': 3,
'unitid': 3,
'address': 0 ,
'quantity': 53 }
Yes...
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 6003,
'quantity': 1
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 200,
'quantity': 10
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 0,
'quantity': 53
HOWEVER - I have seen issues when requesting too much data in quick succession - you might want to put a rate limiter after the function / before the modbus getter
Benja
16 February 2021 19:37
3
var msg1 = (
{payload:
'fc': 3,
'unitid': 3,
'address': 0,
'quantity': 1 }
var msg2 = ({
payload:
'fc': 3,
'unitid': 3,
'address': 200 ,
'quantity': 10 }
var msg3 = ({
payload:
'fc': 3,
'unitid': 3,
'address': 0 ,
'quantity': 53 }
return [msg1, msg2, msg3];
I meant something like this,
finally its working
thx
This code I posted earlier (lets call it VERSION 1)...
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 6003,
'quantity': 1
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 200,
'quantity': 10
node.send({
payload: {
'fc': 3,
'unitid': 3,
'address': 0,
'quantity': 53
is exactly the same as what you are asking for...
var msg1 = {
payload: {
'fc': 3,
'unitid': 3,
'address': 0,
'quantity': 53
var msg2 = {
payload: {
'fc': 3,
'unitid': 3,
'address': 200,
'quantity': 10
var msg3 = {
payload: {
'fc': 3,
'unitid': 3,
'address': 0,
'quantity': 53
return [[msg1,msg2,msg3]]
All 3 messages are sent out one after the other.
If you want a function node with 3 outputs then change the return to return [msg1,msg2,msg3];
BUT since you send the outputs of your functions to the same place - there is literally zero point in sending separate outputs. In fact the first version (VERSION 1) that I first posted will guarantee the order of events.
Benja
16 February 2021 21:15
5
thax for the explanation, the problem is that I don't know how to separate the arrays after reading the data, that's why I occupy 3 flex nodes.
Looking at that code, you look like you could benefit from using buffer-parser (it was designed for taking PLC/Modbus data and making sense of it)
e.g. it turns [2,5,12,55,123,6,1,234,6,3] into
"temperature": 12.5,
"humidity": 47.4,
"speed": 123
fake data
I will suggest something different. I guess you just want to read the registers on a time based interval. For that purose i used cronplus node. Can define different json to be sent on different intervals. Used it for reading modbus tcp.
