Hi guys!
I have bollean inputs and want to have an output which is TRUE if ONE of the three inputs is true.
What‘s the easiest way to do that?
Wishes
Andreas
Hi guys!
Wishes
Andreas
This is an easy one - but I suspect that the question isn't quite right ![]()
Just use a switch node and check if payload is true
It will pass the message on if any message that arrives is true
...but what if 2 of the inputs are true?
Is this what you want?
[{"id":"8de4dac57ab390a5","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic2","payload":"true","payloadType":"bool","x":140,"y":1740,"wires":[["b4c57c93001b84df"]]},{"id":"b4c57c93001b84df","type":"junction","z":"a0d0f696507d618e","x":280,"y":1760,"wires":[["a39f0bd25c5def86","43efefe2ee156e2e"]]},{"id":"14b1c9cf8a5a3f33","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic2","payload":"false","payloadType":"bool","x":150,"y":1800,"wires":[["b4c57c93001b84df"]]},{"id":"a39f0bd25c5def86","type":"and","z":"a0d0f696507d618e","name":"","topic":"","property":"payload","minData":"3","x":450,"y":1660,"wires":[["f12ba76774ecb30a"]]},{"id":"43efefe2ee156e2e","type":"or","z":"a0d0f696507d618e","name":"","topic":"","property":"payload","minData":"1","x":450,"y":1760,"wires":[["93d310374af76254"]]},{"id":"3eb28492ef83a2a9","type":"junction","z":"a0d0f696507d618e","x":280,"y":1640,"wires":[["43efefe2ee156e2e","a39f0bd25c5def86"]]},{"id":"2cc3bf5f14175362","type":"junction","z":"a0d0f696507d618e","x":280,"y":1880,"wires":[["a39f0bd25c5def86","43efefe2ee156e2e"]]},{"id":"f12ba76774ecb30a","type":"debug","z":"a0d0f696507d618e","name":"debug 27","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":1660,"wires":[]},{"id":"93d310374af76254","type":"debug","z":"a0d0f696507d618e","name":"debug 26","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":700,"y":1760,"wires":[]},{"id":"2274c8c775d6dd84","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic1","payload":"true","payloadType":"bool","x":140,"y":1620,"wires":[["3eb28492ef83a2a9"]]},{"id":"3b70577ea11ce441","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic1","payload":"false","payloadType":"bool","x":150,"y":1680,"wires":[["3eb28492ef83a2a9"]]},{"id":"29b24e6cc693cfab","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic3","payload":"true","payloadType":"bool","x":140,"y":1860,"wires":[["2cc3bf5f14175362"]]},{"id":"9039559762e56e4c","type":"inject","z":"a0d0f696507d618e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"topic3","payload":"false","payloadType":"bool","x":150,"y":1920,"wires":[["2cc3bf5f14175362"]]},{"id":"aa0b522928e906bd","type":"comment","z":"a0d0f696507d618e","name":"@mschaeffler/node-red-logic","info":"","x":500,"y":1840,"wires":[]}]
