Hello all,
Is there a way to change the orientation of the map dynamically on worldmap page ?
Any idea on this topic ?
I presume you mean this node. https://flows.nodered.org/node/node-red-contrib-web-worldmap
If you read the documentation, under commands the is an optional property
- rotation - rotate the base map to the specified compass angle.
indeed it is in the doc, I didn't saw it, thanks
