I have been stress-testing dashboard-2 nodes with big data messages, as discussed in Msg size limit in Dashboard 2.0 (messages beyond a certain size break the client connection).
I have now found out that the issue is not with the input msg size, but rather with the msg size of the node's response, emitted by this.send() (once I limit the response size, I am able to send big data arrays, with hundreds of thousands of elements, in a single message).
If my measurements are correct, responses bigger than ~825KB fail and break the client connection. Increasing apiMaxLength in settings.js, has no effect.
Am I missing any other setting here?
The issue is consistent and easy to simulate.
The template receives array dimensions, creates an array of objects, stringifies it (to enable measuring its size) and sends it using this.send(). For objects with 5 properties, an array up to 6980 elements (825KB) will go through, a bigger array crashes the socket connection (with no browser or server exception, other than the disconnect notification).
"id": "44b742873403c498",
"type": "inject",
"z": "f6d5b8d748838f68",
"props": [
"p": "maxRows",
"v": "6980",
"vt": "num"
"p": "maxProps",
"v": "5",
"vt": "num"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 910,
"y": 580,
"e32e14cab9556887"
"id": "e32e14cab9556887",
"type": "ui-template",
"group": "2bc9d878f96a3d0e",
"page": "",
"ui": "",
"name": "Create big response",
"order": 5,
"width": "8",
"height": "3",
"head": "",
"format": "<template>\n <div>\n Columns: {{msg.maxCols}}<br>\n Rows: {{msg.maxPros}}\n </div>\n</template>\n\n<script>\nconst $scope = this;\n\n// Socket listener\n$scope.$socket.on('msg-input:' + this.id, function(msg)\n{\n const rows = [];\n for (let i=0; i < msg.maxRows; i++)\n {\n const row = {id:i};\n for (let j = 1 ; j <= msg.maxProps ; j++)\n row[\"Prop\"+j] =\"DATA-\" + (i) + \"-\" + j;\n rows.push(row);\n }\n msg.payload=JSON.stringify(rows);\n msg.responseLength = \"\"+(msg.payload.length/1024).toFixed(2)+\"KB\";\n $scope.send(msg);\n});\n\n</script>\n",
"storeOutMessages": true,
"passthru": false,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 1100,
"y": 580,
"aa240d6ff17944eb"
"id": "aa240d6ff17944eb",
"type": "debug",
"name": "debug 126",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 1245,
"y": 580,
"wires": [],
"l": false
