Which is why I also suggested you look at how to store data.
It sounds as if you want both values to be stored. So that when  new message comes in
for door it picks up the latest value of help
and if a new help message comes in it picks up the latest version of door.
See
[{"id":"bc95c600.8a7ff","type":"inject","z":"44c6969d.6be6c","name":"","topic":"","payload":"Door1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":125.5,"y":121,"wires":[["e74f067f.68d2e8"]]},{"id":"40776dfa.949a94","type":"inject","z":"44c6969d.6be6c","name":"","topic":"","payload":"Help1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":136,"y":260,"wires":[["527b8184.c9bcc8"]]},{"id":"c04f22bc.ece308","type":"inject","z":"44c6969d.6be6c","name":"","topic":"","payload":"Door2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":126,"y":160,"wires":[["e74f067f.68d2e8"]]},{"id":"2a297a3f.5793fe","type":"inject","z":"44c6969d.6be6c","name":"","topic":"","payload":"Help2","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":135,"y":301,"wires":[["527b8184.c9bcc8"]]},{"id":"e74f067f.68d2e8","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"door","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":272.5,"y":141,"wires":[["6eed31e.adb2c5"]]},{"id":"527b8184.c9bcc8","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"help","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":279,"y":278,"wires":[["20dcad07.a5a60a"]]},{"id":"6eed31e.adb2c5","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"door","pt":"global","to":"door","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":499.5,"y":140,"wires":[["3d0d745f.6cadcc"]]},{"id":"20dcad07.a5a60a","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"help","pt":"global","to":"help","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":495,"y":277,"wires":[["7f16357b.4d0cdc"]]},{"id":"3d0d745f.6cadcc","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"help","pt":"msg","to":"help","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":734,"y":138,"wires":[["4747696d.be2c88"]]},{"id":"7f16357b.4d0cdc","type":"change","z":"44c6969d.6be6c","name":"","rules":[{"t":"set","p":"door","pt":"msg","to":"door","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":724,"y":276,"wires":[["4747696d.be2c88"]]},{"id":"4747696d.be2c88","type":"template","z":"44c6969d.6be6c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"These are the two values in one message: {{door}}&{{help}}","output":"str","x":881.5,"y":206,"wires":[["7d2010bf.72b2e8"]]},{"id":"7d2010bf.72b2e8","type":"debug","z":"44c6969d.6be6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":926.5,"y":350,"wires":[]}]
This only works after you have a value for each, but there are ways around that as well.
