I have some subflows that I want to share with other projects and therefore, I tried to package them as a module. I followed the documentation about subflow modules in the "Creating Nodes" guide. I was able to package one of my subflows and install the module. The subflow also works as expected. However, it shows up as "sf:undefined" in the palette with a default color and icon. Node-RED seems to ignore the settings in the subflow json. How can I give it a proper name, color, icon and category? How can I package more than one subflow in the same module?
For testing, I've created a trivial subflow that simply sets the payload to "foo".
foo.json
"id": "f0880b6cfc44474e",
"type": "subflow",
"name": "foo",
"info": "",
"category": "",
"in": [
"x": 40,
"y": 80,
"id": "b2442e2050f229ce"
"out": [
"x": 360,
"y": 80,
"id": "b2442e2050f229ce",
"port": 0
"env": [],
"meta": {
"module": "foo",
"type": "foo",
"version": "0.0.1",
"author": "Oliver Treichel <oliver.treichel@bayer.com>",
"desc": "Description",
"keywords": "foo"
"color": "#DDAA99"
"type": "change",
"z": "f0880b6cfc44474e",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "foo",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 200,
"y": 80,
This subflow gets registered via flow.js
const fs = require("fs");
const path = require("path");
module.exports = function(RED) {
const subflowFile = path.join(__dirname,"foo.json");
const subflowContents = fs.readFileSync(subflowFile);
const subflowJSON = JSON.parse(subflowContents);
RED.nodes.registerSubflow(subflowJSON);
The module package.json looks like this:
"name": "foo",
"version": "0.0.1",
"description": "Test",
"keywords": [
"foo"
"author": "Oliver Treichel <oliver.treichel@gmx.de>",
"license": "UNLICENSED",
"node-red": {
"nodes": {
"foo": "foo.js"
I've also created a foo.html as for "normal" modules, but this didn't work either.
RED.nodes.registerType('foo',{
category: 'misc',
color: '#a6bbcf',
defaults: {
inputs:1,
outputs:1,
icon: "file.png",
label: function() {
return this.name||"foo";
</script>
<script type="text/html" data-template-name="foo">
<div class="form-row">
<label for="node-input-name"><i class="fa fa-tag"></i> Name</label>
<input type="text" id="node-input-name" placeholder="Name">
</div>
</script>
<script type="text/html" data-help-name="foo">
<p>A simple node that adds foo to the message</p>
</script>
