Hi can please someone help my parse data from AHT1X-0x38. Message is:
"topic": "tele/tasmota_E9B332/SENSOR",
"payload": "{\"Time\":\"2022-06-23T10:08:05\",\"AHT1X-0x38\":{\"Temperature\":27.2,\"Humidity\":47.7,\"DewPoint\":15.1},\"TempUnit\":\"C\"}",
"qos": 0,
"retain": false,
"_msgid": "bcebcc7a418e0045"
i have use this but now this not work
problem ist sensor name
Thanks you wery much.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
because AHT1X-0x38 has the special minus character in the object property
you have to access it instead with this alternative syntax
var c = msg.payload["AHT1X-0x38"].Temperature
which, as Steve showed, is what you get using the Copy path command
