Parse json data into function
Hi all!
I just want to parse Json data using Tasmota devices via MQTT into a function in order to obtain certain data that i need and put into a message via Telegram.
The main idea is to obtain via MQTT the actual hostname and firmware version of the Tasmota, so i can be aware whenever my Tasmotas are updated or not.
So, i have this so far...
I can correctly obtain the data i need...
Then inside my function i do this...but i only obtain the hostname, which is correctly because im calling that object.
But if want to join the two objects into my function that is where it fails...i don't know how to do that and i only obtain errors.
Thanks a lot!
With a switch node you can select "Has Key" (StatusNET) which will only pass it through if it exists.
Or in a different way, send the commands via http
which produces this output
flow
[{"id":"78f70367.0d9074","type":"inject","z":"f60f1f2f.6b207","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":180,"wires":[["da30c2f2.db772"]]},{"id":"da30c2f2.db772","type":"function","z":"f60f1f2f.6b207","name":"hosts","func":"const tasmotas = [\"10.0.0.26\",\"10.0.0.27\",\"10.0.0.24\"]\nconst status= \"/cm?cmnd=Status%200\"\nfor(let x=0;x<tasmotas.length;x++){\n    \n    node.send({url:\"http://\"+tasmotas[x]+status})\n    \n    \n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":250,"y":180,"wires":[["f4d416e1.f85e98"]]},{"id":"2cf16dc2.081e4a","type":"debug","z":"f60f1f2f.6b207","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":200,"wires":[]},{"id":"f4d416e1.f85e98","type":"http request","z":"f60f1f2f.6b207","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","x":390,"y":180,"wires":[["b210a677.3baaf8"]]},{"id":"b210a677.3baaf8","type":"batch","z":"f60f1f2f.6b207","name":"","mode":"count","count":"3","overlap":0,"interval":10,"allowEmptySequence":false,"topics":[],"x":530,"y":180,"wires":[["5bfe3e09.1d8c88"]]},{"id":"5bfe3e09.1d8c88","type":"join","z":"f60f1f2f.6b207","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":650,"y":180,"wires":[["2cf16dc2.081e4a","96e34734.d82e1"]]},{"id":"96e34734.d82e1","type":"change","z":"f60f1f2f.6b207","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.{ \"name\":**.Hostname, \"ipAddress\":**.IPAddress, \"version\":**.Version  }","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":160,"wires":[["63f37354.f04534"]]},{"id":"63f37354.f04534","type":"debug","z":"f60f1f2f.6b207","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":990,"y":160,"wires":[]}]
Edit the "hosts" node with the ip's of your devices and update the batch node to the number of outputs you are expecting.
Cool!
Thanks a lot for that aproach!
Hi @bakman2
I was working on your last post and i've realized that the information that i can retrieve is in somehow "faked" because there is a node that do that. It only fake the information about the devices.
I need to have the real information without faking it so i can take the right decision later on.
This is my actual flow:
[{"id":"1c91208.fec35df","type":"html","z":"13e3e683.083059","name":"","property":"payload","outproperty":"payload","tag":"tr","ret":"html","as":"multi","x":490,"y":680,"wires":[["24ff0fa2.0bd78"]]},{"id":"24ff0fa2.0bd78","type":"html","z":"13e3e683.083059","name":"","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":619,"y":680,"wires":[["dd64a4c0.568c58"]]},{"id":"99820d79.ce827","type":"http request","z":"13e3e683.083059","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://ota.tasmota.com/tasmota/release/","tls":"","persist":false,"proxy":"","authType":"","x":350,"y":680,"wires":[["1c91208.fec35df"]]},{"id":"dd64a4c0.568c58","type":"switch","z":"13e3e683.083059","name":"","property":"payload[0]","propertyType":"msg","rules":[{"t":"cont","v":"tasmota.bin","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":750,"y":680,"wires":[["f16ce907.a37a88"]]},{"id":"3fc09af7.0c6176","type":"inject","z":"13e3e683.083059","name":"Repeat every 15 days","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1296000","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":720,"wires":[["f8eb8e72.964b3","99820d79.ce827"]]},{"id":"f16ce907.a37a88","type":"change","z":"13e3e683.083059","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"availableVersion","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"payload[6]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":924,"y":680,"wires":[["a7dbed0c.cc957"]]},{"id":"a7dbed0c.cc957","type":"join","z":"13e3e683.083059","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1090,"y":720,"wires":[["d3fe8df0.e1e6e"]]},{"id":"d3fe8df0.e1e6e","type":"function","z":"13e3e683.083059","name":"compare tasmota web version with tasmota version","func":"var webVersion = msg.payload.availableVersion; //get web version\nvar deviceData = msg.payload.deviceData; //get array of devices\nvar current = [];//where results will go\nvar old = [];\n\n//loop through each device\nfor (let i = 0; i < deviceData.length; i++) {\n    let device = deviceData[i]; //get this device\n    var v = device.version; //get device version\n    device.version = v.split(\"(\")[0]; //split on \"(\" then take first element [0]\n    device.webVersion = webVersion; //optional\n    device.match = (device.version == device.webVersion); //compare device version to webVersion\n    if(device.match) {\n        current.push(device); //add result\n    } else {\n        old.push(device); //add result\n    }\n}\n\nmsg.payload = {\n    current: current,\n    old: old,\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1370,"y":680,"wires":[["88f9688.fd3c198","14555b50.363735"]]},{"id":"f8eb8e72.964b3","type":"function","z":"13e3e683.083059","name":"hosts","func":"const tasmotas = [\"192.168.1.40\",\"192.168.1.180\"]\nconst status= \"/cm?cmnd=Status%200\"\nfor(let x=0;x<tasmotas.length;x++){\n    node.send({\n        url:\"http://\"+tasmotas[x]+status,\n        ip: tasmotas[x]\n    })\n}\nmsg.complete = true;\nmsg.payload = null;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":330,"y":760,"wires":[["bb624e81.2c073"]]},{"id":"bb624e81.2c073","type":"function","z":"13e3e683.083059","name":"fake device requests","func":"var fake_httprequests = {\n    \"192.168.1.40\": {\"Status\":{\"Module\":1,\"DeviceName\":\"luz_prueba\",\"FriendlyName\":[\"luz_prueba\"],\"Topic\":\"luz_prueba\",\"ButtonTopic\":\"0\",\"Power\":0,\"PowerOnState\":3,\"LedState\":1,\"LedMask\":\"FFFF\",\"SaveData\":1,\"SaveState\":1,\"SwitchTopic\":\"0\",\"SwitchMode\":[0,0,0,0,0,0,0,0],\"ButtonRetain\":0,\"SwitchRetain\":0,\"SensorRetain\":0,\"PowerRetain\":0},\"StatusPRM\":{\"Baudrate\":115200,\"SerialConfig\":\"8N1\",\"GroupTopic\":\"tasmotas\",\"OtaUrl\":\"http://ota.tasmota.com/tasmota/release/tasmota.bin\",\"RestartReason\":\"Power On\",\"Uptime\":\"14T20:22:27\",\"StartupUTC\":\"2021-01-05T21:28:02\",\"Sleep\":50,\"CfgHolder\":4617,\"BootCount\":304,\"BCResetTime\":\"2020-06-12T04:30:48\",\"SaveCount\":3440,\"SaveAddress\":\"F9000\"},\"StatusFWR\":{\"Version\":\"9.2.0(tasmota)\",\"BuildDateTime\":\"2020-12-21T15:03:40\",\"Boot\":7,\"Core\":\"2_7_4_9\",\"SDK\":\"2.2.2-dev(38a443e)\",\"CpuFrequency\":80,\"Hardware\":\"ESP8285\",\"CR\":\"404/699\"},\"StatusLOG\":{\"SerialLog\":2,\"WebLog\":2,\"MqttLog\":0,\"SysLog\":0,\"LogHost\":\"\",\"LogPort\":514,\"SSId\":[\"BellVille2.4ghz\",\"\"],\"TelePeriod\":300,\"Resolution\":\"558180C0\",\"SetOption\":[\"002A8009\",\"2805C8000100060000005A00000000000000\",\"00000228\",\"00006000\",\"00000000\"]},\"StatusMEM\":{\"ProgramSize\":586,\"Free\":416,\"Heap\":23,\"ProgramFlashSize\":1024,\"FlashSize\":1024,\"FlashChipId\":\"144051\",\"FlashFrequency\":40,\"FlashMode\":3,\"Features\":[\"00000809\",\"8FDAC787\",\"04368001\",\"000000CF\",\"010013C0\",\"C000F981\",\"00004004\",\"00001000\"],\"Drivers\":\"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,45\",\"Sensors\":\"1,2,3,4,5,6\"},\"StatusNET\":{\"Hostname\":\"luz_prueba-6101\",\"IPAddress\":\"192.168.1.40\",\"Gateway\":\"192.168.1.1\",\"Subnetmask\":\"255.255.255.0\",\"DNSServer\":\"192.168.1.1\",\"Mac\":\"60:01:94:CA:37:D5\",\"Webserver\":2,\"WifiConfig\":4,\"WifiPower\":17},\"StatusMQT\":{\"MqttHost\":\"192.168.1.8\",\"MqttPort\":1883,\"MqttClientMask\":\"DVES_%06X\",\"MqttClient\":\"DVES_CA37D5\",\"MqttUser\":\"mosquitto\",\"MqttCount\":4,\"MAX_PACKET_SIZE\":1200,\"KEEPALIVE\":30},\"StatusTIM\":{\"UTC\":\"2021-01-20T17:50:29\",\"Local\":\"2021-01-20T18:50:29\",\"StartDST\":\"2021-03-28T02:00:00\",\"EndDST\":\"2021-10-31T03:00:00\",\"Timezone\":\"+01:00\",\"Sunrise\":\"08:34\",\"Sunset\":\"17:28\"},\"StatusSNS\":{\"Time\":\"2021-01-20T18:50:29\"},\"StatusSTS\":{\"Time\":\"2021-01-20T18:50:29\",\"Uptime\":\"14T20:22:27\",\"UptimeSec\":1282947,\"Heap\":23,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":4,\"POWER\":\"OFF\",\"Wifi\":{\"AP\":1,\"SSId\":\"BellVille2.4ghz\",\"BSSId\":\"C8:D7:19:52:9D:27\",\"Channel\":10,\"RSSI\":100,\"Signal\":-40,\"LinkCount\":4,\"Downtime\":\"0T00:09:52\"}}},\n    \"192.168.1.180\": {\"Status\":{\"Module\":1,\"DeviceName\":\"luz_escritorio_garaje\",\"FriendlyName\":[\"luz_escritorio_garaje\"],\"Topic\":\"luz_escritorio_garaje\",\"ButtonTopic\":\"0\",\"Power\":1,\"PowerOnState\":3,\"LedState\":1,\"LedMask\":\"FFFF\",\"SaveData\":1,\"SaveState\":1,\"SwitchTopic\":\"0\",\"SwitchMode\":[0,0,0,0,0,0,0,0],\"ButtonRetain\":0,\"SwitchRetain\":0,\"SensorRetain\":0,\"PowerRetain\":0},\"StatusPRM\":{\"Baudrate\":115200,\"SerialConfig\":\"8N1\",\"GroupTopic\":\"sonoffs\",\"OtaUrl\":\"http://thehackbox.org/tasmota/release/tasmota.bin\",\"RestartReason\":\"Software/System restart\",\"Uptime\":\"0T23:52:49\",\"StartupUTC\":\"2021-01-19T17:57:41\",\"Sleep\":50,\"CfgHolder\":4617,\"BootCount\":488,\"BCResetTime\":\"2020-04-15T00:57:39\",\"SaveCount\":6301,\"SaveAddress\":\"F7000\"},\"StatusFWR\":{\"Version\":\"8.5.0(tasmota)\",\"BuildDateTime\":\"2020-09-09T11:41:02\",\"Boot\":7,\"Core\":\"2_7_4_1\",\"SDK\":\"2.2.2-dev(38a443e)\",\"CpuFrequency\":80,\"Hardware\":\"ESP8285\",\"CR\":\"430/699\"},\"StatusLOG\":{\"SerialLog\":2,\"WebLog\":2,\"MqttLog\":0,\"SysLog\":0,\"LogHost\":\"\",\"LogPort\":514,\"SSId\":[\"BellVille2.4ghz\",\"\"],\"TelePeriod\":300,\"Resolution\":\"558180C0\",\"SetOption\":[\"002A8109\",\"2805C8000100060000005AFF000000000000\",\"00000200\",\"00006000\",\"00000000\"]},\"StatusMEM\":{\"ProgramSize\":595,\"Free\":408,\"Heap\":23,\"ProgramFlashSize\":1024,\"FlashSize\":1024,\"FlashChipId\":\"144051\",\"FlashFrequency\":40,\"FlashMode\":3,\"Features\":[\"00000809\",\"8FDAE797\",\"04368001\",\"000000CD\",\"010013C0\",\"C000F981\",\"00004004\",\"00000000\"],\"Drivers\":\"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37\",\"Sensors\":\"1,2,3,4,5,6\"},\"StatusNET\":{\"Hostname\":\"luz_escritorio_garaje\",\"IPAddress\":\"192.168.1.180\",\"Gateway\":\"192.168.1.1\",\"Subnetmask\":\"255.255.255.0\",\"DNSServer\":\"192.168.1.1\",\"Mac\":\"DC:4F:22:F9:7D:69\",\"Webserver\":2,\"WifiConfig\":2,\"WifiPower\":17},\"StatusMQT\":{\"MqttHost\":\"192.168.1.8\",\"MqttPort\":1883,\"MqttClientMask\":\"DVES_%06X\",\"MqttClient\":\"DVES_F97D69\",\"MqttUser\":\"mosquitto\",\"MqttCount\":1,\"MAX_PACKET_SIZE\":1200,\"KEEPALIVE\":30},\"StatusTIM\":{\"UTC\":\"2021-01-20T17:50:30\",\"Local\":\"2021-01-20T18:50:30\",\"StartDST\":\"2021-03-28T02:00:00\",\"EndDST\":\"2021-10-31T03:00:00\",\"Timezone\":\"+01:00\",\"Sunrise\":\"08:34\",\"Sunset\":\"17:28\"},\"StatusSNS\":{\"Time\":\"2021-01-20T18:50:30\"},\"StatusSTS\":{\"Time\":\"2021-01-20T18:50:30\",\"Uptime\":\"0T23:52:49\",\"UptimeSec\":85969,\"Heap\":23,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":1,\"POWER\":\"ON\",\"Wifi\":{\"AP\":1,\"SSId\":\"BellVille2.4ghz\",\"BSSId\":\"C8:D7:19:52:9D:27\",\"Channel\":10,\"RSSI\":94,\"Signal\":-53,\"LinkCount\":1,\"Downtime\":\"0T00:00:06\"}}},\n}\n\nmsg.payload = fake_httprequests[msg.ip]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":520,"y":760,"wires":[["ec9d2b2e.071af8"]]},{"id":"ec9d2b2e.071af8","type":"join","z":"13e3e683.083059","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":750,"y":760,"wires":[["17b0f4da.d1640b"]]},{"id":"17b0f4da.d1640b","type":"change","z":"13e3e683.083059","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.{ \"name\":**.Hostname, \"ipAddress\":**.IPAddress, \"version\":**.Version }","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"deviceData","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":760,"wires":[["a7dbed0c.cc957"]]},{"id":"14555b50.363735","type":"function","z":"13e3e683.083059","name":"Send not updated devices to TG","func":"var oldDevices = msg.payload.old;\n\nif(oldDevices && oldDevices.length) {\n  msg.payload.chatId = 587232739;\n  msg.payload.type = 'message';\n  msg.payload.content = `Se encontraron ${oldDevices.length} dispositivo con la versión de Tasmota desactualizada:\\n` + msg.payload.old.map(e => `NOMBRE: ${e.name}, IP: ${e.ipAddress}, VER: ${e.version}`).join(\"\\n\")\n  return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1330,"y":740,"wires":[["236c15d.5dd1cea"]]}]
Thanks a lot!
