Parsing data on a html website
hello,
i'm trying to understand how to use the html node. i have some difficulties in parsing data from a html.
for exercise i'm trying to take some information from the website oraesattaco
i can't take the time and more in general i have some difficuties on every attribute that change
[{"id":"13f05733.be7349","type":"http request","z":"b2f1b60c.9e0988","name":"","method":"GET","ret":"txt","url":"https://www.oraesatta.co/","tls":"","x":1070,"y":120,"wires":[["ebdcef3b.c917d"]]},{"id":"1d24ba3b.c92936","type":"inject","z":"b2f1b60c.9e0988","name":"","topic":"trigg","payload":"gris","payloadType":"flow","repeat":"","crontab":"","once":false,"x":900,"y":120,"wires":[["13f05733.be7349"]]},{"id":"649d9b39.7a7874","type":"debug","z":"b2f1b60c.9e0988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1470,"y":120,"wires":[]},{"id":"ebdcef3b.c917d","type":"html","z":"b2f1b60c.9e0988","name":"","property":"","outproperty":"","tag":"#top-box > h1","ret":"html","as":"single","x":1260,"y":120,"wires":[["649d9b39.7a7874"]]},{"id":"9964e6e2.0df348","type":"http request","z":"b2f1b60c.9e0988","name":"worldonometers","method":"GET","ret":"txt","url":"https://www.oraesatta.co/","tls":"","x":1080,"y":180,"wires":[["e4256f52.38ffe"]]},{"id":"5e816bee.94e7c4","type":"debug","z":"b2f1b60c.9e0988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":1470,"y":180,"wires":[]},{"id":"e4256f52.38ffe","type":"html","z":"b2f1b60c.9e0988","name":"","property":"","outproperty":"","tag":"#clock","ret":"text","as":"single","x":1230,"y":180,"wires":[["5e816bee.94e7c4"]]},{"id":"37f2414a.d90fbe","type":"inject","z":"b2f1b60c.9e0988","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":900,"y":180,"wires":[["9964e6e2.0df348"]]}]
i'm able to take string data.. but i'm not able to take data that change.. i'm not sure that this is the correct way.. How i have to do?
thank you for your help
You cannot access data that is calculated on the web page by javascript. The html node fetches the source of the page but does not run the javascript.
Thank you for your answer. Do you have any idea how I can get that calculated data? Is it possible in other way?
Not that I am aware of, other than to work out what the js is doing and replicate that in a function node for example.
I’ve not done it in Node-RED but if you google “scrape javascript tendered page” there are techniques using third party websites or python
Thank you! I will try!
A typo there I think, should be rendered possibly.
yep, rendered ooooops!
