Pass Placeholder string via msg to ui_dropdown
Based on this link node-red-dashboard/config-fields.md at master · node-red/node-red-dashboard · GitHub it should be possible to assign text to placeholder msg.place, but it doesn't work
My end goal is to have dynamic text before selection is done. If I understand it is not possible to pass msg.label
        "id": "9fc31133c5fcda57",
        "type": "inject",
        "z": "ee47c5e8.e17bd",
        "g": "c79d322bfa03965c",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 120,
        "y": 1500,
                "1ab92735079bc89c"
        "id": "5434c618c577b6e3",
        "type": "ui_dropdown",
        "name": "Module4Tags",
        "label": "",
        "tooltip": "",
        "place": "",
        "group": "384ac69668844f73",
        "order": 7,
        "width": 0,
        "height": 0,
        "passthru": true,
        "multiple": true,
        "options": [
                "label": "",
                "value": "",
                "type": "str"
        "payload": "",
        "topic": "topic",
        "topicType": "msg",
        "className": "",
        "x": 460,
        "y": 1500,
        "id": "1ab92735079bc89c",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "options",
                "pt": "msg",
                "to": "[\"M1100.StatDrvFwd\",\"M1100.StatDrvBwd\",\"M1100.ix_DrvRdy\",\"M1100.ix_MtSw\"]",
                "tot": "json"
                "t": "set",
                "p": "place",
                "pt": "msg",
                "to": "PlaceHolder",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 280,
        "y": 1500,
                "5434c618c577b6e3"
        "id": "384ac69668844f73",
        "type": "ui_group",
        "name": "Tags",
        "tab": "89a7ee01bc78fc67",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "89a7ee01bc78fc67",
        "type": "ui_tab",
        "name": "Trace2",
        "icon": "dashboard",
        "order": 7,
        "disabled": false,
        "hidden": false
The following configuration properties of ui widget nodes can be set by using a msg.ui_control
So set msg. ui_control.palace
To "Placeholder"
[edit]
You can also use {{label}} in the config label field and send msg.label, or any other msg var you wish.
